07-24-2011, 08:20 PM #1Awaiting Activation
- Jun 2007
- aurora
Wanting to paint some engine bay plastics
Was wondering what sandpaper would you use to sand engine bay plastics like the plastic on the bottom that attaches to the air lid? Not trying to remove scratches just want to sand it to remove grease and oil then paint it. Thanks!
07-24-2011, 08:25 PM #2Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
I always use 220.
Rims. Plastic and other parts
07-25-2011, 04:28 PM #3
ill try some 400 1st and see the results. just re sand after the 1st coat of paint to fill any imperfections.
07-25-2011, 05:35 PM #4
After sanding, some "wax and grease" remover that you can get at any paint store is the best bet, followed by a wipe down with a tack cloth. I also use denatured alcohol for paint prep with good results.
07-27-2011, 07:47 PM #5
1) Sand it down and clean it very well to remove all grease and oil. The part should appear very dry, and chalky looking if you have done it right.
2) Apply some adhesive promoter to the part, there are many kinds you can select from.
3) Apply a high build primer. This will cover any scratches you might have, It goes on fairly thick and gives you a lot of opportunity to sand it smooth.
4) Apply your paint and clear coat.
These steps work every time. It is not the fastest way to go, but it is the right way. And I know you do not want to do it twice.
Let me know if you have any questions.
Thanks, Roger
Wanting Paint...What Color Should i go with ??
By LS194Z28 in forum Camaro / SSReplies: 30Last Post: 07-25-2009, 04:39 PM -
Paint engine Bay
By blk_jaws in forum Appearance SectionReplies: 1Last Post: 06-09-2009, 12:25 PM -
Complete Tan leather Interior + Plastics, Stock Ri
By eddielb in forum Western MembersReplies: 8Last Post: 05-24-2008, 07:59 PM -
links of my 98 ta ,new engine and paint
By mad3125 in forum Member's RidesReplies: 0Last Post: 03-09-2008, 10:19 AM -
For those wanting pics of my engine bay
By Warbird in forum Almost Anything GoesReplies: 1Last Post: 06-04-2006, 03:12 PM
