Results 1 to 20 of 53
06-26-2011, 08:31 PM #1Senior Member
- Jan 2010
- texas
silver- 2000 formula
Power steering cooler install in pics
A good way to increase the life of your PS pump is to cool the fluid.....GM knew this and decided to use engine coolant to cool the PS fluid on WS6 birds (camaros too?)....a good idea with bad implementation as the pipe used to cool the PS fluid often (always?) failed and began to mix coolant with PS fluid.....which is never a good idea......so if you have a water cooler on your F bod its not a question on if the cooler will fail....its a question of when.....so if you have a cooler on your bird .......ditch it ASAP......and if you dont have a cooler on your bird.......you can install one real easy......Derale makes a thin long tranny cooler which makes for a excellent PS cooler......I mounted it behind the air dam......which may lot get a lot of direct air flow.....but it gets enough flow IMO to get the job done.............follow along
06-26-2011, 08:31 PM #2Senior Member
- Jan 2010
- texas
06-26-2011, 08:31 PM #3Senior Member
- Jan 2010
- texas
06-26-2011, 08:33 PM #4Senior Member
- Jan 2010
- texas
06-26-2011, 08:34 PM #5Senior Member
- Jan 2010
- texas
06-26-2011, 08:34 PM #6Senior Member
- Jan 2010
- texas
there is some plastic protector on the side of the fins.....i removed it before i installedLast edited by sjsingle1; 06-26-2011 at 09:06 PM.
06-26-2011, 08:35 PM #7Senior Member
- Jan 2010
- texas
the kit comes with some hose......but you will need more......glad i thought of getting more......BTW its goodyear hoseLast edited by sjsingle1; 06-26-2011 at 09:05 PM.
06-26-2011, 08:36 PM #8Senior Member
- Jan 2010
- texas
center it....i used stainless self tapping screws to hold it up
06-26-2011, 08:37 PM #9Senior Member
- Jan 2010
- texas
06-26-2011, 08:37 PM #10Senior Member
- Jan 2010
- texas
remove the return line from the rack........used a 18mm wrenchLast edited by sjsingle1; 06-26-2011 at 08:43 PM.
06-26-2011, 08:38 PM #11Senior Member
- Jan 2010
- texas
06-26-2011, 08:39 PM #12Senior Member
- Jan 2010
- texas
my return line had this pinch in the line........does yours?
06-26-2011, 08:40 PM #13Senior Member
- Jan 2010
- texas
i cut the line and flared it to hold the new hose
06-26-2011, 08:40 PM #14Senior Member
- Jan 2010
- texas
06-26-2011, 08:41 PM #15Senior Member
- Jan 2010
- texas
06-26-2011, 08:41 PM #16Senior Member
- Jan 2010
- texas
06-26-2011, 08:41 PM #17Senior Member
- Jan 2010
- texas
06-26-2011, 08:42 PM #18Senior Member
- Jan 2010
- texas
06-26-2011, 08:43 PM #19Senior Member
- Jan 2010
- texas
all done.......and cooler now
06-27-2011, 05:19 AM #20Senior Member
- Apr 2008
- Madison, WI
Welcome back
Power Steering Cooler
By DUBB in forum External EngineReplies: 8Last Post: 08-22-2010, 11:38 AM -
power steering cooler
By 99pewterta in forum General HelpReplies: 2Last Post: 10-22-2009, 10:44 PM -
Looking for Power Steering Oil Cooler
By NOS99HAWK in forum Parts Wanted / TradeReplies: 4Last Post: 07-02-2009, 04:18 AM -
By knoll5150 in forum General HelpReplies: 2Last Post: 12-03-2007, 08:42 AM -
Power Steering Cooler?????
By VetNutJim in forum Camaro / SSReplies: 8Last Post: 01-06-2007, 08:18 PM
