Thread: Power Steering Cooler
08-19-2010, 07:50 PM #1
So after diagnosing my car, found out i have a bad PS cooler (milky ps fluid, oily in coolant).......... after doing lots of searching i have found equally opposing opinions, although GM called it a "cooler" it seems that it might be used to heat the ps fluid. Reason why i'm questioning it is apparently every ls1 fbody in canada was sold with a ps cooler (Not 1 parts store sells the 1 piece rad hose setup w/o ps cooler)
Originally i was going to do what a lot of people did, install aftermaket air cooler and put the 1 piece rad hose in, which im still leaning towards. Either that or just connect the hoses and put the 1 piece rad hose in (wont cool the fluid)
All i dont want to do is more harm by cooling the fluid more than it should be, particularly in the winter. I live in a pretty mild climate of vancouver and it rarely gets below freezing.
opinions required asap as i need to get this done!
you guys rule
08-20-2010, 05:30 AM #2Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Ditch the cooler!! They all fail sooner or later..... Glad my 98 doesn't have one...
08-20-2010, 07:11 AM #3
08-20-2010, 08:06 AM #4Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
Well the pump wont live long with coolant in it
08-20-2010, 09:25 AM #5
08-21-2010, 04:08 AM #6
I'm anal about these things so if it has a cooler I would replace the cooler. They are available on ebay or through the dealer. BTW 10271554 is the part number for the full length hose.
08-21-2010, 04:05 PM #7
08-21-2010, 06:04 PM #8
+2 for Daddy and FBJ's posts. It's there for a reason. Everything on our car is prone to fail at some point. Once you replace the cooler, it is likely that the rest of the car will expire before you have to do it again.
08-22-2010, 12:38 PM #9
Have to agree- replace it with the cooler. Funny thing is, here I can't find a parts store that has the two piece hose! Dumb arse at the Pontiac parts counter thought I was nuts when I said it has a PS cooler.
2000 Pontiac Firehawk #0041 of 742
Do you run a Power Steering cooler?
By b.lee in forum External EngineReplies: 16Last Post: 12-07-2020, 03:55 PM -
Looking for Power Steering Oil Cooler
By NOS99HAWK in forum Parts Wanted / TradeReplies: 4Last Post: 07-02-2009, 05:18 AM -
power steering cooler
By knoll5150 in forum General HelpReplies: 2Last Post: 12-03-2007, 09:42 AM -
By Blackout01 in forum General HelpReplies: 2Last Post: 08-03-2007, 10:54 AM -
By Phlash_riot in forum External EngineReplies: 2Last Post: 11-26-2006, 10:39 PM
