Results 1 to 20 of 43
Thread: Rattle
06-17-2011, 08:27 PM #1
Rattle
Driver side rear... I've replaced just about every suspension part you can think of. I still have this incessant, inconsistent rattle. It doesn't always make the sound, but I guess If I had to establish a pattern, it seems to make the noise when I'm on uneven roads.
Also when you push down on the trunk, you get this squeaky rubbery sound.
Any ideas?
06-18-2011, 12:51 AM #2
Could be anything from the rubber graments on the shocks, to the exaust pipe hitting. All I can say is welcome to the sounds of an fbody.
02 Z28/LS1 NBM - TIN CAN RACING
Full bolt on, weight reduction mods, dyno tuned by FROST = 330hp/342tq New PB = 12.74 @109
06-18-2011, 02:24 AM #3
Check the spare tire hold down and the jack.
06-18-2011, 05:05 AM #4
Exhaust where it crosses over top of the panhard brace is a good culprit. The rear heat shields in that area can also rattle.
06-18-2011, 08:18 AM #5
Adjust your hatch bump stops
06-19-2011, 07:33 PM #6
I don't know... it almost sounds like I have a loose DRIVER side tire or the brake rotor is chattering inconsistently. Bottom line the sound is coming from the Driver side and with it comes the feeling like I have an out of round tire on the driver side.
On the side note was that if the car is parked, you can push on the trunk and as the suspension compresses you can hear a squeak. I tried pushing down on it today with the hatch up and I still get the sound, so Thanks to the guy that said to adjust the bump stops... but it won't help
06-19-2011, 07:37 PM #7
Was the first thing I checked... sound is generating on the opposite side
My car never did this until this winter and I hoped with rising temperatures the sounds would go away, but they haven't.
read my first more recent post. I hadn't thought to try this, but I popped the hatch and pushed down on the car... the squeaky/rubbery sound still happens.
06-19-2011, 07:39 PM #8
06-19-2011, 07:39 PM #9
Did you crawl under it and check where the exhaust crosses over the upper pan hard bar like Jeff suggested? My exhaust was hitting in that area as it comes very close to coming in contact where it goes over the axle. Of course, this would be on the passenger side, not the driver side where you say the sound is coming from though.
Is the car sitting level when you look at it? Just ruling out the fact that maybe the spring is not seated properly on one side.
Another thing you could do is crawl under there and look for any fresh, shiny marks on anything metal. This would indicate where two components were rubbing against one another.
06-19-2011, 07:46 PM #10
Yeah, I looked at the exhaust, but I have a pan hard bar relocation kit which gives me extra clearance. I also just replaced the shocks with Koni's thinking this would get ride of the noise. It seemed to for the first 10 miles, but nevertheless its still there. I've tried checking for shiny metal marks, but there are none that stand out to me... I am wondering if the bearings are shot on my UMI LCA's.
06-19-2011, 07:49 PM #11
Well the only other thing that comes to mind since you have new suspension components is perhaps something needs to be torqued down again. LCA's loose, PHB loose, etc.
Does it definitely sounds like metal on metal?
06-19-2011, 07:58 PM #12
the chatter YES! If it wasn't for the fact that our rear disks are held in place by the rear tire, I would swear that the right rear disk is wobbling back there, but when I get the Chatter I pick up a slight vibration in the left rear, like my tire is out of balance/out of round.
Now I have also been mentioning another sound. this sound sounds like a rubbery squeak or a bad mattress/couch squeak. I can manufacture this sound every time I push down on the rear end of the car and make the suspension compress.
And I tried tightening all my suspension components down too... Worked for about a day... I'm out of ideas, that's why I got on here.Last edited by AKA Speedy; 06-19-2011 at 07:59 PM. Reason: more explanation
06-19-2011, 08:05 PM #13
Maybe you have a bad wheel bearing
06-19-2011, 08:07 PM #14
Check the king nut on the rear shocks to be sure it's tightened properly, with all the isolaters present and that the bushing is properly squashed..
06-19-2011, 08:25 PM #15
06-19-2011, 08:30 PM #16
06-20-2011, 06:29 AM #17
- Jun 2010
- Central Florida
Navy Blue, Dark Cherry- 98 M6 TA, 87 A4 TA
if tightening everything worked for a day I would think it's suspension related, if you have poly bushings (in my experience) they need to be re-lubed every year or 2 or they squeak. I'd drive the rear up on ramps and crawl under while a friend pushes down on the quarter pannel to make the noise you can usually find the noise really quick if it's something you can repeat in your driveway like that. Take it apart lube it up and reassemble.
06-20-2011, 06:50 AM #18
- Oct 2008
- Coral Springs, Fl
Do you have spherical rod ends on your panhard bar or lcas?
06-20-2011, 08:00 PM #19
I'll have to do that and see if I can track that noise... Now I need a game plan for the chatter
I would think they're fine... I just had the shocks replaced not but a little while ago with Koni's. I'm wondering if I blew the driver side shock somewhat out because when I went to 315's I cut the bump stops out and bottomed the suspension out on the exhaust a couple times... the exhaust is on the passenger side though, so it probably saved that shock... wouldn't been there for the driver side one though. I inspected the shock today and there doesn't seem to be any oil running down the side of the shock, or any sign that it might have. Also, the car sits level on a flat paved surface.
No, I went with the the poly bushings. The LCA's are non adjustable, the Panhard bar is a single adjustable.
06-20-2011, 08:01 PM #20
Oh and sorry for the late reply... I'm in the military and put in some long hours some days.
5.3 rattle rattle knock knock........ NOOO!!
By crawdad369 in forum GM TrucksReplies: 5Last Post: 02-14-2008, 01:38 PM -
I have a rattle!
By bluefields88 in forum General HelpReplies: 5Last Post: 12-13-2007, 04:16 AM -
Rattle?
By BlueBomber in forum Internal EngineReplies: 2Last Post: 09-30-2007, 01:47 PM -
Rattle..
By kirbbssters FireHawk in forum Firebird / WS6Replies: 6Last Post: 05-24-2007, 11:31 AM -
Bad rattle
By atilla2000tax2 in forum General HelpReplies: 7Last Post: 11-05-2006, 11:34 AM
