Thread: Trouble Codes
06-16-2011, 12:47 PM #1
Trouble Codes
So, last week I got a P1637 code...cleared it hasn't popped again (yet), now it's giving me P0131 and P0171. I also just had to have the power steering pressure hose replaced....Any ideas????
06-16-2011, 03:22 PM #2
start by cleaning your MAF sensor with CRC MAF cleaner. The codes you are gettign are for bank 1 (drivers side) O2 sensor pre cat. I will clean the MAF and if it does go away then try swapping the sensor with the passenger side. If the code follows to the passenger side then the sensor is bad. Have you inspected the wires to make sure they arent pinched or melt down?
06-22-2011, 06:37 PM #3Mustang Eater
- Feb 2010
- Springfield, Missouri, United
Maroon- 2000 z28 6 speed
Cleaning the maf.. that usually works..
2001 B4C Totaled 4/25/11
2000 Z28 M6 Cammed N' Slammed (SVT KLR)
06-23-2011, 08:08 PM #4
Cleaning MAF helped, but I'm still getting the code. Anybody know what real-time pressures i should be seeing for the LS2 MAF? Trying to narrow it down between if the maf went bad or if its the pcm going bad or if its an electrical problem.
Help: Trouble codes!!
By SandmanWs7 in forum General HelpReplies: 4Last Post: 07-07-2009, 03:02 PM -
trouble codes
By "B4C" in forum General HelpReplies: 2Last Post: 12-04-2008, 07:06 AM -
Question: Trouble Codes
By TransAmFanatic in forum General HelpReplies: 9Last Post: 09-19-2008, 12:15 PM -
Trouble Codes!!!
By 2MuchFun in forum Computer & TuningReplies: 11Last Post: 06-07-2007, 12:50 PM -
Trouble Codes?
By ssxcytmnt in forum General HelpReplies: 8Last Post: 03-08-2007, 04:52 PM
