Thread: Trouble codes!!
07-07-2009, 06:10 AM #1
Trouble codes!!
SO my pops truck is due for an inspection. 1998 Chevy C1500 with a 4.3 V6. I noticed the MIL light on. I get a code P1351 Ignition Coil Control Circuit High Voltage. Does that mean that the Ignition Coil is bad?
I have no clue where to start here. I did change the Distributor cap, rotor, wires, and plugs ( needed to do that anyways) any I deas?
Thanks!!
07-07-2009, 08:37 AM #2
I've never had to trouble shoot that particular code on a vehicle but I have swapped the coil on my 4.3 and it's a pretty cheap coil and easy to swap. Might start there. In the past I've had quite a bit of trouble with the ignition on my 4.3 and I've swapped pretty much every part out at one time or another.
07-07-2009, 09:10 AM #3
I've been researching and seems most people are saying two things. 1) Ignition coil needs to be changed. 2) That the timing is off. Which is possible. My pops had a guy work on the truck awhile back and he did remove the whole disrtibutor. I will change the coil since that might be cheaper than taking it in to get the timing adjusted.
Thanks!
07-07-2009, 02:17 PM #4
Is the truck running badly or just setting the code? If the timing was off it'd run like ass.
07-07-2009, 03:02 PM #5
trouble codes
By "B4C" in forum General HelpReplies: 2Last Post: 12-04-2008, 07:06 AM -
Question: Trouble Codes
By TransAmFanatic in forum General HelpReplies: 9Last Post: 09-19-2008, 12:15 PM -
Trouble Codes!!!
By 2MuchFun in forum Computer & TuningReplies: 11Last Post: 06-07-2007, 12:50 PM -
Trouble codes need help
By wicked1 in forum External EngineReplies: 2Last Post: 04-10-2007, 10:19 AM -
Trouble Codes?
By ssxcytmnt in forum General HelpReplies: 8Last Post: 03-08-2007, 04:52 PM
