Thread: tach and speedo not working
03-24-2006, 04:01 PM #1hrsepwrfrkGuest
Hey im new to the LS1 scene...just recently bought a 98 trans/am and when i bought it the speedo and tach didnt work...any ideas? they are just stuck at 0
03-26-2006, 02:49 AM #2hrsepwrfrkGuest
anyone at all?
03-26-2006, 09:33 AM #3Senior Member
- Jul 2005
- Jacksonville, FL
Well, thumbing through my helms it says the first thing you need to do is an IPC (instrument panel check) with a scan tool. For example under the tach diagnosis it says to sweep the tach with the tool, if it doesn't sweep then replace the instrument cluster. Speedo diagnosis is a little more complicated, but you get the idea. The tool will also read any codes present. Other than checking all your fuses and the connector/wiring to the panel don't know what else to tell you. Hope this helps...
03-26-2006, 10:03 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
Just thought of something else, have you tried resetting the PCM?
Help: Tach Not Working
By splitfinger09 in forum General HelpReplies: 0Last Post: 09-14-2009, 03:26 PM -
Autometer speedo and tach
By 65ls1 in forum Stereo and ElectronicsReplies: 3Last Post: 12-21-2008, 07:04 AM -
tach not working
By Fbody4ever in forum Camaro / SSReplies: 1Last Post: 07-02-2008, 11:32 PM -
Woah.. 2010 Camaro interior photographed naked - showing speedo/tach and torque guage
By terps in forum Camaro / SSReplies: 29Last Post: 01-31-2008, 11:45 AM -
My tach quit working
By socmninja in forum Camaro / SSReplies: 5Last Post: 04-07-2007, 07:39 AM
