    Junior Member 65ls1's Avatar
    fountain valley california
    1965 chevelle 2drht ss
    Autometer speedo and tach
    Any suggestions on how to hook up sport comp gauges on a 2000 camaro pcm in a 65 chevelle?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    What transmision do you have? Is the speedo mechanical or electric? You might be able to hook the tach wire to a coil, if that doesn't work you will need a converter. Then you can use the wire from the pcm.
    Im running a turbo 400 with a electronic vss and reluctor ring. I was told you cant run the tach off of the coil because the signal is incorrect. Do you know what converter will work? Thanks!
    Feb 2006
    Orange County, NY
    always dirty
    There is a wire coming from the pcm that you can try. Otherwise you can use one of these http://www.autometer.com/cat_accesso...il.aspx?vid=99. I would call autometer first to see if it will work. For the tranny you just have to use the output for the vss.
  1. Autometer monster tach install
    By Asian LSX in forum Computer & Tuning
    Last Post: 10-30-2011, 12:55 PM
  2. Autometer speedo
    By motavated in forum Automatic Transmission
    Last Post: 07-30-2011, 06:00 PM
  3. Autometer Tach Install
    By fordkiller in forum General Help
    Last Post: 06-01-2006, 02:07 PM
  4. tach and speedo not working
    By hrsepwrfrk in forum General Help
    Last Post: 03-26-2006, 10:03 AM
  5. autometer tach
    By toysruskid62 in forum General Help
    Last Post: 08-28-2005, 02:30 PM
