Results 1 to 18 of 18
    Member daytonayellaz's Avatar
    May 2011
    Indiana
    2002 WS6
    What to do before Dyno Tune???
    Trying to get as much stuff done before I have my car dyno tuned and want everyones thoughts that care to share.
    The car.... 02 WS6/M6 with 38k miles. Has factory LS6 Intake
    The mods... and these are all fresh virtually no miles.
    1..Rapid Dominator 2 Series Cam Kit
    231/239 on a 113 w/ 0.617/0.624
    Chrome Moly Pushrods, Manley Dual Springs, Manley Ti Retainers, Manley Steel Spring Seats and new GM valve seals.
    2.. GM HD Timing chain set was installed
    3.. Rapid Ported LS6 oil pump
    4.. Fuel filter
    5.. Oil change with Mobil 1 and new filter
    6.. Street tuning
    Other work done...
    Pace Setter LT's
    Pace Setter ORY (no cats)
    Magnaflow Catback
    K&N
    SLP Lid
    SLP MAF
    I was going to put NGK TR5 plugs in before the tune.
    I also am going to put in new 02 sensors.
    It has factory plug wires... should I replace these? They look fine, like I said 38k miles.
    Installing a 160 Thermostat.
    So what does everyone think? I dont want to have to keep going back spending money to retune for little stuff added later. Thanks for all your help! Just want to say Thank-You to all the help provided from the members on this site allready! Its a great place to hang!
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    clean air filter?
    May 2011
    Indiana
    2002 WS6
    Quote Originally Posted by jiveass View Post
    clean air filter?
    Yea.... Has a brand new K&N
    Oct 2009
    pewter
    99 trans am
    Quote Originally Posted by daytonayellaz View Post
    guess i overlooked that detail...
    May 2011
    Indiana
    2002 WS6
    No biggie
    Junior Member Keith01's Avatar
    May 2011
    2001 Camaro
    I'm guessing air pump removed with your LT's?
    Member ls1wallen's Avatar
    Jul 2009
    Saint Peters, MO
    2001 Formula
    I always change the oil before I go beat on my car.
    i'd clean the maf and put a paper filter back in... don't want to waste $ on a dyno tune to have oil get on your MAF and screw stuff up...
    Apr 2010
    IN
    Charge your video camera
    May 2011
    Indiana
    2002 WS6
    Quote Originally Posted by Keith01 View Post
    Yes...AIR is gone.
    Quote Originally Posted by ls1wallen View Post
    Yes... That was just done as well
    This I hadnt thought about....Very good point! Put the K&N back in after dyno tune....right?
    Quote Originally Posted by BashamWS6 View Post
    This is a very important one as well....Hadnt thought of this one either. I need to write some stuff down to be sure to take with me!
    Thanks everyone!! Keepem comin!
    PA
    Ray Charles blue
    1492
    How about put some nitrogen in the tires.
    May 2011
    Indiana
    2002 WS6
    Quote Originally Posted by TLS_Addict View Post
    Well....I hadnt thought of that one, but think I will do wiper blades first..
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I think you have everything in order. Spaz's comment about the K&N should be taken as "the oiled K&N filter is known to get oil on the MAF over time and can cause your MAF to read improperly".
    May 2011
    Indiana
    2002 WS6
    Thanks Jon... I had never thought about that happening before. It makes perfect sense though. I will be removing it for the dyno tune and give the MAF a quick clean before the dyno tune session. Thanks!
    You might want to ditch the K&N and get an Amsoil filter too. The main issue with K&N really only comes in when people clean them and then re-oil them and too much oil is used. They have been known to gunk up the MAF then, which is something you don't want happening.
    the worst part is the oil gets in the U shapped bars that the resistors are connected to and it's a real pain in the ass to clean it out of there...
    May 2011
    Indiana
    2002 WS6
    Amsoil makes a air filter? Have a part # handy by chance? What kind of filter do you run?
    On my Procharger build I will be running the air filter supplied by ATI. It is a lot different than what you would use.
    I don't have a part number, but they are a Sponsor here. Maybe you can contact them and ask or someone else will chime in.
  1. Question: Frost tune or Dyno tune?
    By 90ARAPAJ in forum Firebird / WS6
    Last Post: 04-15-2012, 12:38 PM
  2. hypertech tune erase my dyno tune?
    By Z28LS1 in forum Computer & Tuning
    Last Post: 02-02-2009, 06:31 PM
  3. Street tune vs Dyno tune?
    By FordStomper in forum Western Members
    Last Post: 01-30-2008, 08:29 PM
  4. dyno tune vs street tune...
    By FordStomper in forum GTO
    Last Post: 01-30-2008, 04:55 AM
  5. whats the diff with a full dyno tune and a street tune?
    By Justin23454 in forum Computer & Tuning
    Last Post: 12-04-2007, 06:31 AM
