Results 1 to 11 of 11
Thread: Frost tune or Dyno tune?
04-12-2012, 11:55 AM #1Junior Member
- Apr 2010
- Sterling Heights, MI
Navy Blue Metallic- 1998 Trans Am
Ok, so, my car needs a tune bad...like real bad..my car needs a tune like Justin Beiber needs to hit puberty. The cross road i'm at is should i take it to the dyno 2 miles away from me? Or go with the frost tune that everyone goes crazy about. Its all basically boltons with a hypertech tune (which needs to be returned to stock according to the dyno shop before they do their part). Suggestions?
04-12-2012, 12:39 PM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
Well, if you have the money I would take it down the street and have them do a full out dyno tune. Most places charge 150.00/hr plus parts. For one hr of dyno time you can get a custom tune by Frost which is what I am running at this time and I love it. Frost set up the software to the stuff you already have on the car. The chassis dyno is better because it is done in real time and you can play with different settings while the car is running and you can also change parts to see what works best. Different tunes for different dollars. Good luck.
04-12-2012, 03:11 PM #3Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Frost tune is excellent but the dyno tune can net you better results since its a customized tune to your car. Just depends on how much you wanna spend. Frost is 150 a dyno tune can run upwards of 400 or more depending on place and how involved they get.
04-12-2012, 06:07 PM #4
For a bolt on car, I would not hesitate to go with a Frost mail order tune. Once you start changing things like the cam and heads, then a dyno tune would be a better choice.
04-12-2012, 06:10 PM #5
04-12-2012, 07:48 PM #6
I vote Frost with your mods. Add more mods with the money saved.
04-13-2012, 10:49 AM #7
04-14-2012, 03:35 AM #8
With bolt-ons Frost....Internal--Dyno.
2 Frost tunes here..
04-14-2012, 04:07 AM #9
I have a frost tune and got it dynoed at the same time, I am only a hour away so it was dynoed by him. If you have basic bolt ons he is your best bet for mail order. Just tell him what you have done and he will get you there.
02 Z28/LS1 NBM - TIN CAN RACING
Full bolt on, weight reduction mods, dyno tuned by FROST = 330hp/342tq New PB = 12.74 @109
04-15-2012, 11:25 AM #10Junior Member
- May 2007
- Pemberton, NJ
Black- 1999 GTP
i have a 01 trans am with a texas motorspeed .609 lift cam, long tube headers and a lid... stock intake/tb etc, has o/r y pipe 3" and 3" spintec catback... no cats though.
Car has a hundred codes that come up and runs so rich at idle, it barely stays running without holding the gas to keep rpms up until warm... almost smells like raw fuel in the air at idle, i'd assume a dyno tune is the only way to go about getting it straightened out? i have no idea what kinda tune or no tune is even on the car, bought it used. Could it run with a factory tune and just be crappy like this?
04-15-2012, 12:38 PM #11
^ Sounds like the previous owner threw a cam in and didn't bother to spring for a dyno tune. Cars run like shit after a cam swap. I'd take it real easy on the car until you can get it to a tuner.
hypertech tune erase my dyno tune?
By Z28LS1 in forum Computer & TuningReplies: 3Last Post: 02-02-2009, 06:31 PM -
Street tune vs Dyno tune?
By FordStomper in forum Western MembersReplies: 2Last Post: 01-30-2008, 08:29 PM -
dyno tune vs street tune...
By FordStomper in forum GTOReplies: 3Last Post: 01-30-2008, 04:55 AM -
whats the diff with a full dyno tune and a street tune?
By Justin23454 in forum Computer & TuningReplies: 6Last Post: 12-04-2007, 06:31 AM -
Handheld Tune?shop Tune? software running on my laptop tune?on my SS
By showtimesteele99SS in forum Computer & TuningReplies: 4Last Post: 04-09-2007, 05:31 AM
