Results 1 to 20 of 24
    Howling coming from rear
    I've got what seems like a howling sound coming from what I think is my rear. I did a break job last week and I only driven it twice since. Both times when I get above 50 it starts to come and go. At 70-80 it becomes more constant. I've done several hard braking and have not had any grinding or pulling so I not sure if it's a break issue.
    Ideas:
    1) Brake Caliber is sticking? (I'm going to check this first.)
    2) Rear is fixing to go boom?
    3) Wheel hub or bearings?
    4) Something else?
    East of Cleveland, Ohio
    99 WS.6 - Modified
    I take it the car did not make the noise before the brake job? If not, I would be suspecting the brakes.
    Update, I was looking around underneath and a walk around looking for leaks, stuff hanging.
    My rear wheels look almost solid black from break dust. Both sides. I'll jack it up this weekend and see what goes.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Check your brakes. And if they are fine, then your rear is letting you know it is time to replace it.
    Pittsburgh
    2008 Hummer H3
    Agree,
    could be axle walk..
    Also check the calipar pins are'nt hanging up or frozen..
    wouldn't I feel that (axle walk)? I get no shimmy or vibrations at all. That's what is so weird.
    Pittsburgh
    2008 Hummer H3
    You may or may not even notice.. It would likely depend on the extent of the end play.. That's why I says check your brake pins...
    Stupid things love to hang up or freeze.. Low temp grease will boil right out under hard braking even on the rear calipars..
    Orlando, FL
    Mean Black
    did you adjust your e brake? if not then check the pins 1st like mentioned. what exactly you replace in the BRAKE job. Did you took off the master cylinder cap when you back off the calipers?
    No I didn't take the cap off.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Might extra pressure in your brake system b/c of that.
    Otherwise, I was thinking hub, but those make more noise when turning as well, at least in my experience.
    Take cap off and bleed system?
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    I would just take it off and see if you get a release of pressure, just my guess.
    I just hoping it's not the "bad" thing for you b/c mine howls like hell at all speeds.
    The howling is bad enough that I heard it over headers and with the T-tops going 80.
    I'm not sure I'm describing quite right by saying it's a howling sound. More like a rubbing or a dragging sound
    Orlando, FL
    Mean Black
    well what happens is that if you dont take the cap off your are forcing that hydralic fluid back into the master cylinder. Since the cap is on and is air tight there is no space to create room for the fluid that needs to come back. I mean it will create room but You can bust the o rings in the master cylinder.
    I will try to take the cap off. Fill to proper level if needed. Then open the bleeder of the back wheels and let it flow for a few seconds. Make sure you dont run out of fluid or you will get air in the system. Re fill to proper level and check them again. I will still check the pins and make sure they are free.
    I did damage a master cylinder once because I didn't took the cap off when i back in the calipers. I destroyed the o rings.
    Orlando, FL
    Mean Black
    chock the wheels and put the rear end on stands. put the car in neutral and try to move the wheels by hand. Do you feel them stuck or dragging?
    I'll have to do that when I get home. That was my plan to see which wheel was dragging. I'm beginning to think it is the fluid pressure because I did forget to take the cap off. I was in a hurry and doing 2 projects at same time. So yeah I hate to say it I rushed it.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Is it constant? Meaning always making noise, whether in gear or not? (I can't remember if you m6 or not)
    Otherwise, Jay's suggestion is the best I can think of right now.
    Orlando, FL
    Mean Black
    did you take the cap after they started dragging or not yet?
    Jay's the winner of how stupid can SMWS6TA be today.....
    I just got back from a 40 mile test drive. I think it's fixed, did various speeds and braking and no sound. Thank God!!
    Seems Jay was right, as soon as I open the cap I heard a burp sound and a hiss of air. I can't believe it still, that I forgot such a simple step.
    At lease it's not a rear going out.
    Orlando, FL
    Mean Black
    Lol don't feel stupid it happens to the best of us.
  1. rear end fluid coming out of the rear tire
    By stangkillan101 in forum Drivetrain
    Last Post: 06-24-2011, 07:42 PM
  2. New Trans, New Rear... it's coming along
    By MrMasterCraft in forum Camaro / SS
    Last Post: 12-03-2010, 12:18 PM
  3. Clunking coming from rear
    By jcws6 in forum Drivetrain
    Last Post: 09-23-2008, 01:14 PM
  4. noise coming from rear end?!?!
    By martinez_z28 in forum Drivetrain
    Last Post: 07-03-2008, 04:57 PM
  5. Howling at startup?
    By MarkuzLS1 in forum External Engine
    Last Post: 06-30-2006, 08:45 AM
