Thread: Temp Gauge
    Member 2000dreambird's Avatar
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    Temp Gauge
    what are the options to make my temp gauge in my 00 read true like they did in the 98's
    Senior Member
    Jacksonville, FL
    No fix I'm aware of. The 98's had a 3 wire ECT, 99 and up 2 wire and goes through the PCM before registering. It's fairly accurate in the lower and high temps once past the "210 range." Only option is an aftermarket gauge and adapt it into the plug on the passenger side head.
    you would probably need to get a pillar pod and a gauge to get an accurate temp gauge like the 98's.
    For the life of me I don't understand why GM did not put in accurate gauges for performance cars. I can understand for general passenger sedans, but not for cars built for performance.
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    from what i understand they did it because people were bringing the cars in to complain everytime it got a little hot and hit the 210 mark so they setup the gauages to show low med and overheated
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    also im thinking about going with the aeroforce OBDII set they read alot of stuff including temp
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs up
    X2 on that, there is a 1/8 NPT port located on the drivers side head (not sure of the side), that the sender will install in.
    SteveC
    O.C. California
    2002 Camaro SS (crashed)
    correct gauge is the whole point but I heard its kind of pain in the ass
    Our cars actually have an accurate temp sender that feeds the PCM. Not sure if it is a standard 0-5 V signal that can be intercepted or not. Also not sure if that same sender feeds the POS stock gauge as I never looked at the schematic.
  1. Question: Oem temp gauge
    By cruzincamaro in forum General Help
    Last Post: 01-27-2012, 09:00 PM
  2. Want to trade Tranny Temp gauge for Oil pressure gauge.
    By jrbonds in forum Parts Wanted / Trade
    Last Post: 07-29-2011, 08:47 AM
  3. temp gauge
    By Darkrider02 in forum General Help
    Last Post: 03-17-2011, 05:02 PM
  4. Hooking up Oil pressure gauge,and Temp Gauge
    By BirdFlewLS1 in forum General Help
    Last Post: 01-15-2008, 06:15 AM
