Results 1 to 1 of 1
Thread: Need direction with L33 into C10
06-05-2011, 07:00 AM #1Junior Member
- Jun 2011
- Ab, Canada
pewter- 70 Chev Nova
I'm going to be recieving a used engine (L33 -05 silverado) from a wrecker in the next week.
I need some input on what to use to run this engine as far as a harness and computer.
I had thought about a carb and dist, but since has figured it would be better to use a fly by wire pedal, and use a stock LS1 intake, with a stock type harness.
I might be able to get the harness out of the truck, but I would be lost trying to do this install on my own.
Is there someone here that can help with locating a few parts to get this combination together? I don't want to break the bank, so if I can get enough info, I could fix the harness myself, but would still need the computer flashed/ unlocked
Any help would be appreciated,
thanks,
Pat
Need a direction to go
By Dpeck76006 in forum General HelpReplies: 17Last Post: 04-25-2015, 03:10 PM -
Need Direction
By allwest in forum General HelpReplies: 3Last Post: 05-04-2014, 03:42 PM -
Is this the right direction???
By nasty99 in forum Internal EngineReplies: 11Last Post: 09-06-2009, 12:41 PM -
What direction should I go?
By 98formy in forum Internal EngineReplies: 1Last Post: 09-10-2008, 08:13 PM -
a little bit of help, i need some direction.
By zero_proto in forum Western MembersReplies: 15Last Post: 06-26-2008, 07:33 AM
