Thread: Is this the right direction???
08-25-2009, 07:44 PM #1Junior Member
- Aug 2009
- Canada
I want to run a cam in my truck
Comp 265LrHR12
specs:
215/223 @.050"
.607/.610 lift
112 lsa / 110 icl
What will this do for me?
99 5.3 chev ec/sb 4x4 33"mudders(Heavy), shorty's, cai, true duals, superchips, eaton posi with 4.56 gears
I have good low end now and don't want to sacrifice any though...
08-25-2009, 09:19 PM #2
Some crazy lift what does the stock stall feel like with 4.56 gears.
08-26-2009, 06:17 PM #3Junior Member
- Aug 2009
- Canada
pretty damn good, instant torque kind of like a diesel, will lay rubber for 10ft or so(both tires very very sticky) It says its a lsr series cam which is supposed to be good for low end power???
08-26-2009, 10:14 PM #4
It looks like a cam that works for a stock stall but that lsa looks like it should be 114. I know the smaller the motor the bigger a cam of any given size acts bigger. If they reccomend it go for it, it might not want to idle low enough for a stock stall.
08-27-2009, 03:05 AM #5
Might work good for you. Going to need a good valve spring upgrade. It says 1300 - 6500 rpm range, but I'd still look for a small stall convertor !!!
08-27-2009, 07:27 AM #6
Cam looks good. I'd bump it up to a 113 LSA to make it a little smoother so it'll get along better with the stock converter.
Also make sure you run a good double valve spring that's rated for a true .650 lift.
08-27-2009, 05:11 PM #7Junior Member
- Aug 2009
- Canada
I will be defiantly be running good springs, that much lift has me worried, the comp guy says nothing to worry about. Will going to a custom grind at 113 really make a difference? I know stock is a 114 lsa .190/.190 .47 lift or something. What kind of power do you think it will make???
08-28-2009, 07:31 AM #8
With a big truck on 33" tires, I wouldn't really be worried about what kind of power it'll make on the dyno
Do a 113 + 4 (advance) and it'll make plenty of power everywhere and be perfectly driveable.
08-28-2009, 04:48 PM #9Junior Member
- Aug 2009
- Canada
Doesn't a custom grind cost like double?? I am interested in more low and mid torque over horse power anyway. I want something that sounds mean as hell, but still very drivable(cold weather in canadian winters
just curious, like 40hp and 40 torque would make me happy at say 2500-5000.
What do you think, am I crazy??
09-02-2009, 06:53 AM #10SaBalaGuest
Ok so I wanna get the cams over with asap, and I really was leaning towards comp cams buttt...
What size should I get, or any other brands that make a good cam that isnt crazy pricey?
09-02-2009, 02:58 PM #11
09-06-2009, 12:41 PM #1215 sec. Oh yeah, its fast
- Apr 2007
- Forest Lake, MN
maroon- 2000 Z28
Get an LQ9 cam. They're a dime a dozen and work well in a 5.3
2000 Z28: Accufab 4150, Vic Jr. 150 shot, Patriot stg 2 heads, big cam, FLT Stg VI 4L60, S60 rear. Waaay more stuff to list. 3100 LBS.
Need a direction to go
By Dpeck76006 in forum General HelpReplies: 17Last Post: 04-25-2015, 03:10 PM -
Need Direction
By allwest in forum General HelpReplies: 3Last Post: 05-04-2014, 03:42 PM -
Need direction with L33 into C10
By pat565 in forum General HelpReplies: 0Last Post: 06-05-2011, 07:00 AM -
What direction should I go?
By 98formy in forum Internal EngineReplies: 1Last Post: 09-10-2008, 08:13 PM -
a little bit of help, i need some direction.
By zero_proto in forum Western MembersReplies: 15Last Post: 06-26-2008, 07:33 AM
