Thread: Auburn rear info needed
03-23-2006, 02:34 PM #1Out in the garage...
- Lakeland, FL
Sebring Silver- 2000 Camaro SS (R.I.P.)
My SS has the SLP Auburn rear option and it's time for a fluid change. Someone told me to never use synthetic in the Auburn or a gasket behind the cover. I used to know a website that listed all of the parts necessary for the fluid change, but I have no idea what it is any more. Any help/info will be appreciated. Thanks!!!
BTW, yes, I've already used the search option......Last edited by 2000 SS #1305; 03-23-2006 at 02:36 PM.
-- J. Bennett
1999 NBM Camaro SS #4312
SLP lid w/ K&N, Delphi/Lucas 42lb injectors, Pacesetter coated LTs, ORY w/ dual cutouts, Magnaflow exhaust, Spec 2+ clutch, Strange 12 bolt, Detroit Truetrac 3.73 gears, BMR adj torque arm, BMR SFCs, BMR LCAs, BMR adj panhard rod, 18" chrome ZO6 wheels
03-23-2006, 07:05 PM #2
I have no idea why you couldnt use a synthetic in a Auburn. My guess would be that synthetic is more "slippery" for lack of a better term than convantional oil and because the Auburn uses a conical clutch material seated in a machined counterbore in the carrier rather than flat clutch packs. Maybe the cones dont grab as easy with synthetic. If you use a conventional gear oil you must use the posi additive, if you use synthetic you do not need it. I have a T-56 in my car and when i changed the ATF to synthetic I found it did not shift as well. Someone told me the synchros didnt work as well with synhetic for just that reason. I switched back to conventional ATF and it shifts good again. Valvoline has a blend of conventional and synthetic, this can not be accomplished by simply adding one bottle of synthetic to a bottle of conventional. Valvoline makes their product special. As for no gasket.. why any one wouldnt use a gasket is beyond me, unless your using silicone which I dont reccomend, it looks all sloppy and orange dripping out of your inspection cover. Gaskets are fine. i know never to replace a O ring sealed part with a gasket or visa versa but I know you can typicaly replace any gasket with silicone depending on the grade of silicone and its application RTV blue, RTV red etc... I think the best way to find out for sure is by contacting Auburn directly.
Auburn Gear Inc.
400 East Auburn Drive
Auburn, IN 46706 - 3499
USA
Phone: (260) 925-3200
Fax: (260) 925-4725
All the parts you need are a gasket, fluid (additive with conventional) and a can of brake cleaner to rinse the particles out of the carrier.
03-24-2006, 06:20 PM #3
Whether you want to use a gasket or not is your choice. I just happen to like RTV better so that's what I use...but whether you have an auburn or not does not affect your gasket or no gasket decision.
03-25-2006, 10:33 AM #4Junior Member
- Mar 2006
- PA
Onyx Black- 2001 Camaro SS
My 01 SS has the Auburn rear. Per my SLP owners manual it states that 80W - 90 mineral (non synthetic) oil and 2 ounes of GM limited slip additive must be used. GM limited slip additive can be purchased at any GM dealer. The AAM cover installed on your rear does not use a gasket. They tell you not to use a gasket for a reason. The rear end housing has been drilled to allow oil flow across the cover for cooling. Using a gasket will block off the ports. Use Loctite black RTV on the cover.
04-01-2006, 09:11 PM #5
don't put synthetic in it.the cone clutches wear fast if you do.
info needed
By duke nukem in forum Suspension and HandlingReplies: 9Last Post: 01-29-2010, 12:33 PM -
For Sale: 4th gen rear end 2.73 3 ch auburn posi
By SexyTransAm in forum Parts For Sale / TradeReplies: 27Last Post: 09-11-2009, 02:24 PM -
Question: Head Info Needed
By Bama99z in forum Internal EngineReplies: 3Last Post: 06-22-2009, 11:06 AM -
info on 12 bolt needed
By toplessHO in forum DrivetrainReplies: 0Last Post: 01-23-2007, 05:51 PM
