Results 1 to 10 of 10
Thread: info needed
01-19-2010, 08:08 AM #1Junior Member
- Aug 2009
- Iceland
white- TRANS AM 2000
info needed
hi, I just installed eibach pro kit springs on my trans am WS6 00 and It seem to be difference between drivers side and passanger side in the back,(the front is ok) the difference is about 1/2". Is it possible that they are not the same left and right side. I have check my installation and it seems to be ok.
thanks
01-19-2010, 08:12 AM #2
Any chance your isolators were accidentally rotated during installation (if they are used with this kit) as that would cause a slight change? Also, with the car lowered and a stock panhard bar, the axle will be slightly offset. This could result in it looking different from side to side.
01-27-2010, 04:41 PM #3Member
- Jul 2008
- new jersey
navy blue metallic- 2000 trans am
this is actually extremely common. some people say it's to account for driver weight, who knows. i have yet to see someone who actually figures out what it is for sure.
01-27-2010, 05:20 PM #4None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
It is a setup for drag racing. It helps the car launch better - torque from the motor shifting to the rear pass side and the spring is set to keep the suspension from compressing as much to tranfer the power to the wheels. My 99 WS6 is setup that way and works quite well. I would first check the other suggestion about the stock panhard bar though. If all is good, then chances are the spring setup you bought it more tailored for drag racing. Your pass side should be the lower side too.
01-27-2010, 05:22 PM #5None Shall Pass
- Jan 2010
PS: are you really in iceland? You runnin studded tires most of the year or what?
01-28-2010, 11:54 AM #6Junior Member
- Aug 2009
- Iceland
01-28-2010, 01:30 PM #7None Shall Pass
- Jan 2010
That's cool. Maybe I'll move there, cause I'm in Ohio and we got a crapload of snow. And it's here for like 6 months. Throw up some pics. You done anything else to it?
01-29-2010, 06:18 AM #8Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
I have never seen a 4th Gen that wasn't slightly higher on the left side vs the right. The difference is usually between 1/4-1/2". First thing is make sure the springs are oriented correctly, The lower pigtails should both face towards the front of the car. Also an adjustable Panhard bar is a must when lowering these cars.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
01-29-2010, 11:20 AM #9
The next time you pull the wheels off take a few minutes and compare the left(driver-side) and right(passenger-side) spring seats on the factory 10 bolt axle tubes. First you'll notice the the drivers-side is flat/level, but when you look at the passenger-side you'll notice it's not level , it's angled back(lower in the rear)towards the rear of the car.
With the factory rear-end it always going to sit a little lower on passenger-side rear, just for the reason stated above, if nothing else.
01-29-2010, 12:33 PM #10Member
- Jul 2008
- new jersey
^^^ never knew! could never find a solid answer.
2005 CTS-V Info Needed
By 73fjbuggy in forum General HelpReplies: 3Last Post: 03-12-2014, 12:11 PM -
Help: Trans am needed info
By BamBam87 in forum General HelpReplies: 9Last Post: 08-02-2009, 01:31 AM -
Question: Head Info Needed
By Bama99z in forum Internal EngineReplies: 3Last Post: 06-22-2009, 11:06 AM -
info on 12 bolt needed
By toplessHO in forum DrivetrainReplies: 0Last Post: 01-23-2007, 05:51 PM
