Results 1 to 20 of 23
    Transmission cooler
    How about some pics of how yours is mounted and where the hoses are routed? I need to install one on our car and rather than "reinventing the wheel" figured it is just easier to see what has worked for you. With the F-body radiator being mounted at an angle, the B&M stacked plate cooler seems to block too much of the gap above the air dam imo.
    Arizona
    Mine was mounted against the condensor, and I bent and flared steel lines to connect it all. I didn't want rubber lines for the tranny to travel too far. Actually tech at the track will limit you to 12" total (if they actually check for it), just a heads up.
    Let me see if I have any pics of it here.
    Arizona
    Here's one.
    Never thought to run steel lines -- good idea. Thoughts on stacked plate versus tube and fin? I have both styles and the stacked plate is quite a bit thicker.
    Arizona
    I run a stack plate style on my chevelle and I do like it better. I used a thinner fin/tube style on the 4th gen because I didn't have as much room to work with.
    What stall converter are you running in the 4th gen?
    Arizona
    A 3400 stall with a 2.1 STR.
    Bonner Springs, KS
    99 TA
    Here is my set-up, B&M cooler, decided to still use the stock one in series since the model i got does not have the low temp bypass feature. Car has a yank 3600ss stall too.
    I originally had bypassed the cooler, here is a pic of that set-up
    Looks like it does not obstruct as much airflow turned like that -- good idea.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    http://www.ls1.com/forums/showthread.php?t=155841
    Mine^
    You could put one where the airpump is and make a scoop to force air to it.
    Senior Member
    Newport, RI
    '00 Formy A4
    Here's one.
    What cooler is that exactly, and is that a FTRA I see?
    I also have a FTRA, and was just wondering about which cooler to go with.
    Knowing your setup would be a great help. Thanks!!
    Arizona
    Quote Originally Posted by StuntmanMike View Post
    I still have the box here somewhere. Give me some time tomorrow and I'll dig it out and see exactly what model cooler that is.
    Yes that is SLP's cold air setup in there as well. It all fits rather snug but it works. I was told years ago that it couldn't be done, so that was insentive to do it and see how it worked
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    Quote Originally Posted by peterlawl84 View Post
    This is how I have mine setup and it works great I got the biggest tranny cooler b&m had I want to say its th 29,000 btu one and its 11inches wide by 3/4" thick. It fit fine and keeps the tranny temps down well in everyday driving
    2002 Arctic White T/A Ws6islife's Avatar
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    what about the fittings on the radiator when doing this can u just leave them unplugged?
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Quote Originally Posted by Ws6islife View Post
    The majority of people will use the aftermarket cooler in conjunction with the radiator cooler. But you could just leave them disconnected if you don't want to use the radiator.
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    the problem is that my fitting is leaking.
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    looking everywhere for a fix. its my lower transmission fitting, i thought i might as well go to an aftermarket cooler.
    Is it leaking coolant or transmission fluid?
    Orlando, FL
    Mean Black
    Have you disconnected it recently or had a tranny flush done? If you have try tighten it down some more but not alot. if it continues to leak pull it out and look at the tip, if you see cracks or looks uneven then it needs to be replaced.
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    It's tranny fluid for sure. I face tightened it down a bit more with no results. I also checked for cracks. I got in a wreck, had to remove and replace the old radiator.
  1. Question: Transmission Cooler
    By fbodyNATION in forum Drivetrain
    Last Post: 07-31-2011, 06:20 PM
  2. Transmission cooler?
    By silverWS6 in forum Drivetrain
    Last Post: 07-10-2011, 12:10 AM
  3. Question: Transmission Cooler
    By pmolina0436 in forum GTO
    Last Post: 04-19-2011, 09:06 AM
  4. transmission cooler lines
    By bobv in forum GTO
    Last Post: 09-19-2009, 11:29 AM
  5. T-56 transmission cooler...??
    By Fibbado in forum Manual Transmission
    Last Post: 06-09-2006, 06:18 AM
