Results 1 to 1 of 1
Thread: changing rear bushings
05-14-2011, 11:27 AM #1Junior Member
- May 2009
- spring hill florida
spice red- 06 gto
sarge if you are out there, what bushings do you recommend for the rear? i read a post by you that just change the rear sway bar link bushings, rear subframe bushings, rear sway bar to frame bushings,should i bother changing the control arm bushings outer? i read that the inner control arm bushings causes problems to drivetrain, appreciate your input.
changing bushings
By motley in forum General HelpReplies: 7Last Post: 04-09-2010, 09:29 AM -
changing frnt & rear bushings
By motley in forum Suspension and HandlingReplies: 0Last Post: 04-06-2010, 04:32 PM -
Rear end bushings bad. where to find some
By Lunatikgixxer in forum Suspension and HandlingReplies: 3Last Post: 03-24-2010, 11:26 AM -
rear axle bushings?
By 02transamce in forum DrivetrainReplies: 2Last Post: 11-05-2009, 03:42 AM -
Changing Radius Rod Bushings
By CanadianGoat in forum GTOReplies: 9Last Post: 06-01-2009, 05:54 AM
