Results 1 to 3 of 3
Thread: rear axle bushings?
11-04-2009, 03:55 AM #1
rear axle bushings?
i think the factory rubber bushings? on my 02 t/a are done,when ever i go over bump even at extremely low speeds the rear end thumps and thuds.i'm going to install a moser 12 bolt soon and i want to replace whatever GM installed to isolate vibration (bushings is the best term i could think of).i looked at a Energy Suspension kit from summit http://www.summitracing.com/parts/EN...R/?image=large , does this kit include these bushings?thanks.if not what do i need.
11-04-2009, 09:53 PM #2Just me
- Nov 2006
- Broken Arrow, OK
I am confused by your post. I am guessing by installing a 12 bolt soon, you are not looking to replace anything internally in the 10 bolt. The title of rear axle bushings leads one to believe you are wanting to replace internal bushings on your 10 bolt though, thats why I am confused. If you are meaning the rear lower control arm bushings, that kit does include them, but for the entire cost of that kit you could buy brand new and much better control arms(which I would recommend). Sorry if I am missing your point all together, maybe pics of the area you are suspecting as your problem would be a good idea
11-05-2009, 03:42 AM #3
sorry for any vagueness,i was tired when making that post,i 'm talking about rubber insulators,if any,used to cushion where the rear axle mounts to the car.i know rubber is use to cushion body mounts,motor mounts,and such,i was wondering if there were any on the rear axle because the car thuds a lot in the rear when going down our driveway and other bumpy roads even at extremely low speeds,and i didn't want to get halfway through the 12 bolt install and think" i could have replaced this while i got this apart".
changing rear bushings
By bobv in forum GTOReplies: 0Last Post: 05-14-2011, 11:27 AM -
changing frnt & rear bushings
By motley in forum Suspension and HandlingReplies: 0Last Post: 04-06-2010, 04:32 PM -
Rear end bushings bad. where to find some
By Lunatikgixxer in forum Suspension and HandlingReplies: 3Last Post: 03-24-2010, 11:26 AM -
Rear Axle/Rear Grear Problem
By ob02z28 in forum Manual TransmissionReplies: 0Last Post: 01-22-2007, 11:32 AM -
prothane poly rear swaybar bushings
By magilla in forum Parts For Sale / TradeReplies: 0Last Post: 01-30-2006, 11:07 AM
