Thread: ls1 runing fat
    May 2010
    port saint luicr fl.
    1998 ss camaro
    Smile ls1 runing fat
    what sensor or could cause to run fat thanks gary
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    The most common part that can cause a car to run rich is the O2 sensors. There are many other causes, a leak in the intake, leak in exhaust before the O2 sensors, cracked or disconnected vacuum hoses, fuel pump, clogged fuel lines/filter.
    Do you have any codes?
    ^^ What he said. What makes you think it is running rich?
    Is there black soot in the tail pipes? Also, if you pull a plug, most likely you can tell if the car is running rich if they look black.
  1. Help: power loss runing bad
    By barryz in forum General Help
    Last Post: 02-02-2011, 09:49 AM
  2. Help: Sticky Pedal/TB, only when runing
    By Vertiviper in forum Firebird / WS6
    Last Post: 06-01-2010, 06:00 AM
  3. Runing lean
    By ls1wallen in forum Computer & Tuning
    Last Post: 11-21-2009, 09:11 AM
  4. Shes runing hot maybe???
    By HighHeat303 in forum General Help
    Last Post: 05-07-2009, 10:04 AM
  5. Question: day time runing lights
    By bballking_2007 in forum Firebird / WS6
    Last Post: 10-19-2008, 02:29 PM
