Results 1 to 3 of 3
Thread: Runing lean
    Member ls1wallen's Avatar
    Jul 2009
    Saint Peters, MO
    2001 Formula
    Runing lean
    So I got my thottle body ported and polished and today I throw a code. I take it up to autozone and I see on there handheld that I am running lean. So is the only way to fix this is a tune?
    First thing to do is disconnect your battery for a few minutes and then try it. This will reset your PCM and force it to "relearn" with the new TB. Your car may hunt for idle and run like crap for a minute or two, but should then smooth out.
    The air flow into the engine is measured by the MAF, so you should be fine. Only problem might be an idle issue if you ported it too close to where the blade seats, thereby allowing addional air in at idle. If you still throw codes, check to ensure that your throttle body and intake ducting are properly secured with no air leaks.
    Jul 2009
    Saint Peters, MO
    2001 Formula
    some one did the porting
  1. Question: car wont stay runing
    By bvar20 in forum Firebird / WS6
    Last Post: 04-04-2014, 04:20 AM
  2. ls1 runing fat
    By gbsss in forum Computer & Tuning
    Last Post: 05-02-2011, 06:01 PM
  3. Help: power loss runing bad
    By barryz in forum General Help
    Last Post: 02-02-2011, 09:49 AM
  4. Help: Sticky Pedal/TB, only when runing
    By Vertiviper in forum Firebird / WS6
    Last Post: 06-01-2010, 06:00 AM
  5. Shes runing hot maybe???
    By HighHeat303 in forum General Help
    Last Post: 05-07-2009, 10:04 AM
