Results 1 to 16 of 16
    Apr 2011
    missouri
    red with black strips
    2000 trans am ws6
    lost locking lug nut key
    I lost my locking lug nut socket key and Idk how to get my wheel off. Anyone got any ideas or tricks
    Member zmg00camaross's Avatar
    missouri
    pewter
    2000 camaro ss
    well you can try and find the same style of key. I have also seen people weld another nut on that nut and then remove it that way.
    Pittsburgh
    2008 Hummer H3
    Beat an old 1/2-drive- 12 point socket onto it that's around the same size..
    Try not to hit the wheel..
    Then try to remove it by hand with a 1/2 drive breaker bar..
    If that does'nt do it, the welding thing will work too..
    All that aside,, You can also purchase a larger "easy out" and pound it into the end of the lock where the threads stick out and try to remove it that way too..
    Another way would be to drill the stud out and use a punch to break the lock out..
    Then you'll need new studs too, since you'll be @ the auto parts buying lug nuts anywho..
    Junior Member sunset02ss's Avatar
    Apr 2011
    Southern California
    Sunset Metallic Orange
    2002 Chevy Camaro SS
    Quote Originally Posted by k-hobbs-ws6 View Post
    lost my key once, could not find replacement, had to use hardened steel impact socket, and pound it onto said lugs, the impact socket was able to shave the softer metal and create a firm bite on keyed lug, to separate impact socket from trashed lug i used my vise. and never went back to locking lugs, this i did on my BMW not my SS. good luck.
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    Had the same prob once.. the shop didn't give it back and I didn't notice it until a couple days later....
    Thankfully I found my card that had the key number on it so I could order a new one.. do you have yours?
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    Apr 2011
    missouri
    2000 trans am ws6
    No I don't have a card but ill try all the ideas when the time comes thanks guys
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by sunset02ss View Post
    +1 and +2. These methods work.
    Junior Member mrc54's Avatar
    Indiana
    2002 Z28 Convertible 4A
    Had the same problem, called around and found a tire dealer with the tools to remove the locks, charged $5 a lock.
    Feb 2010
    Greenwood, IN
    Light Pewter Metallic
    I had to do this for my CTS-V
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Quote Originally Posted by mrc54 View Post
    My suggestion exactly. I had the same problem as well. My local tire shop did it for $15 overall.
    Coral Springs, Fl
    Sunset Orange Metalic
    I've beat a socket over it and was able to remove it easily that way
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Since my idea was already mentioned, I'll try and contribute.
    If you elect to keep them/ get new ones, the locking nut, IIRC, is supposed to be the first one taken off and the last put on. I guess it's suppose to prolong the life of them.
    Omaha, NE
    2000 Z28 Camaro
    Maybe try one of those universal sockets
    Jan 2011
    pevely missouri
    dark blue metallic
    2002 camaro z28
    yeah i beat a socket on get it off now before your stuck someplace undesireable!
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Smittro beat me to it.
    Member jsmith564`'s Avatar
    Apr 2009
    covington ga
    yellow
    2004 gto
    bolt removal kit.. all autoparts stores have them. cheap, easy as 1, 2, 3
  1. Question: Doors locking by themselves
    By 4get gto in forum General Help
    Last Post: 03-05-2009, 02:22 PM
  2. Lost my locking lugnut key
    By JonB in forum Wheels and Tires
    Last Post: 05-31-2008, 09:52 AM
  3. Locking or Non-Locking TC?
    By Wulfe13 in forum Automatic Transmission
    Last Post: 06-23-2006, 12:17 PM
  4. TC keeps locking and unlocking...Why?
    By The Scientist in forum Automatic Transmission
    Last Post: 05-06-2006, 09:34 AM
