Page 1 of 3 123 LastLast
Results 1 to 20 of 51
    Apr 2011
    va
    1987 camaro
    LS1 alternator problems
    I've burned up 5 alternators and I dont know why. the wiring seems but but the volt gauge on the dash reads almost at 18 volts.
    any idea as to what could cause this?
    Pittsburgh
    2008 Hummer H3
    What car? Is your 87 camaro an LS1 swap?
    If so sounds like something maybe wired incorrectly..
    More info needed...
    Pittsburgh
    2008 Hummer H3
    Oh and Welcome to LS1.com..
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Agree, more info is needed.
    Are you running a sound system? Does your sound system have a multiple batteries to it?
    Is the voltage regulator getting replaced with the alt? Are the alts used? Re-manufactured? Brand new?
    Apr 2011
    va
    1987 camaro
    yea its swapped, 87 camaro with a 99 camaro ls1 drivetrain. The wiring is fine i cant find any issues there, the alt turn on wire reads 10.2 volts like it should...im stumped on this one. i went through 3 remans and 2 new alts. no sound system except for a sony head unit and 2 speakers.
    Apr 2011
    oklahoma
    biue
    1998 firebird
    Check engine grounds and chassis grounds for corrosion or missing.There may be high resistance in system..
    Apr 2011
    va
    1987 camaro
    so all i found online anywhere says that wire should only get 5 volts...so why the hell is mine getting 10.2 volts?
    Apr 2011
    oklahoma
    biue
    1998 firebird
    Do you have a 470ohm resister in the small red wire?
    Apr 2011
    va
    1987 camaro
    Quote Originally Posted by waterman74 View Post
    no i used the whole 4th gen harness and i was told i wouldnt need it, if i do i'll put one in if that will fix the problem
    Apr 2011
    va
    1987 camaro
    well the resistor did'nt help anything
    Senior Member
    texas
    2000 formula
    is it a built harness........or pulled from a car harness?
    Apr 2011
    va
    1987 camaro
    pulled from a 99 ss
    Bird Rehab Center ThunderChicken's Avatar
    Dec 2010
    Mebane, NC
    Check your starter. Could be pulling too much voltage.
    Apr 2011
    oklahoma
    biue
    1998 firebird
    How many wires on voltage regulator plug??
    Apr 2011
    va
    1987 camaro
    how could the starter be doing that when its only used to start the car?
    it only has 1 wire in the plug
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by Shmack2004 View Post
    I think the L terminal should have 12 volts from the PCM. Maybe you have a bad PCM
    Apr 2011
    va
    1987 camaro
    i thought that too but it did the same thing in the 99 before i pulled it. im not using the PCM from that car either. this is the most irritating problem i have ever had
    Apr 2011
    oklahoma
    biue
    1998 firebird
    per alldata trouble shooting on charging systems 1999 camaro (quote)
    The L terminal must be a resistance circuit eather through a charge indicator or the PCM. If direct battery voltage is applied to the generator at the L terminal, the regulator will eventually be destroyed,causing repeat failure.
    AGAIN, check all engine grounds and B+ connections on alternator completly through to the battery for corrision and make sure they are tight.
    Madison, WI
    2001 Silverado Z71
    Oops yep your right. I found that info in the service manual also.
    Shmack2004, you need to trace your wiring and figure out why you have 10 volts on the alt L terminal. What PCM are you using?
    Apr 2011
    va
    1987 camaro
    i've checked all the power and ground wires, they are all tight and not corroded. i traced the red wire back to the PCM and its fine. The PCM is model number 12200411. this is really blowing my mind
  1. alternator or what problems???
    By firebird71 in forum GTO
    Last Post: 01-23-2024, 12:18 PM
  2. Help: Having Alternator PROBLEMS
    By Awal98TA in forum General Help
    Last Post: 11-23-2020, 08:04 AM
  3. Alternator Questions/Problems Please help
    By Firebirdformula in forum Firebird / WS6
    Last Post: 06-30-2010, 04:30 PM
  4. Help: Alternator Problems
    By MrMasterCraft in forum Camaro / SS
    Last Post: 03-04-2010, 11:37 AM
  5. Alternator/generator problems
    By Stoneflye in forum General Help
    Last Post: 08-22-2007, 02:29 AM
