Results 1 to 3 of 3
Thread: Alternator Problems
03-04-2010, 01:42 AM #1Senior Member
- Nov 2009
- NOVA
2002 C5 - M6 - Blue- 2000 Z28 - A4 - Pewter
Alternator Problems
Ok, so I know this is in the wrong section, and it'll probably get moved, but I need help FAST. '02 Yukon, went out to start the truck this morning to let it warm up like I always do, started it, turned the heat knob to full blast, shut the door, walked back inside. Maybe 5 minutes later, come back outside lights are dim, all gauges read like the truck is off
So I shut it off, start the camaro, and run jumper cables to the truck for about 10-15 minutes. Truck started, voltage dropped from 14-10 in a little over a minute...
So I'm convinced it's the alternator, but my question is what size do I need? I thought with rear defrost that it was necessary to run a 140? I looked at 2 parts stores websites and it seems they range anywhere from 90-130? The truck has rear defrost, rear heat/ac, etc..... can somebody PLEASE tell me what I need?
03-04-2010, 04:50 AM #2
From GM's SI:
Base
Generator Model
Delphi AD230
Rated Output
102 A
Load Test Output
71 A
Optional (Dual)
Generator Model
Delphi AD244
Rated Output
130 A
Load Test Output
91 A
Bosch® Generator
Generator Model
Bosch® 15755900
Rated Output
130 A
Load Test Output
91 A
03-04-2010, 11:37 AM #3Senior Member
- Nov 2009
- NOVA
Excellent, thank you very much man!!!
alternator or what problems???
By firebird71 in forum GTOReplies: 7Last Post: 01-23-2024, 12:18 PM -
Help: Having Alternator PROBLEMS
By Awal98TA in forum General HelpReplies: 8Last Post: 11-23-2020, 08:04 AM -
LS1 alternator problems
By Shmack2004 in forum General HelpReplies: 50Last Post: 11-18-2020, 07:39 AM -
Alternator Questions/Problems Please help
By Firebirdformula in forum Firebird / WS6Replies: 15Last Post: 06-30-2010, 04:30 PM -
Alternator/generator problems
By Stoneflye in forum General HelpReplies: 0Last Post: 08-22-2007, 02:29 AM
