Results 1 to 11 of 11
Thread: Wiring
    Junior Member legacyy21's Avatar
    Omaha
    Wiring
    Hey guys whats going on? So today I was messing around on my Trans Am and I noticed that the previous owner still had wiring for a sub and an amp hooked up. I have a Rockford Fosgate p200.2 amp that I had gotten from my brother in law. So the power and ground wires right now are 8 gauge wires and on Rockford's website it recomends a 4 gauge wire would it not be smart to go ahead and use this 8 gauge wire or should i go out and get a 4 gauge wiring kit? Thanks in advance!
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    I would get the 4 gauge wire. Don't want to risk a fire. What size fuse does your amp have?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    The 8 gauge wire might not be enough to drive the amp, it may not work it at all. It depends on the amp, I ran 8 gauge for a 100watt amp for my front door speakers on previous vehicles.
    It might be good enough, but 4 is always a safe bet.
    How many watts is the amp and subwoofer?
    Omaha
    The fuse size in the amp is a 30. I know that the amp is also throwing out 200 watts rms.
    Feb 2006
    Orange County, NY
    always dirty
    Then it should be fine. My amp is the same rating and I have 8 gauge. Just run a 30 amp fuse up near the battery.
    Omaha
    Alrighty sounds good! Thanks guy for the quick responses, I appreciate it!
    Omaha
    Alright so I hooked it all up and it was all running but there was a weird smell, kinda smelt like something burning but didn't see any smoke or anything, do you think this could be from the ground and battery wires being an 8 gauge wire?
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by legacyy21 View Post
    Smell only when it's running? How old is the amp? Has been exposed the weather? What did you use as ground? Subs working?
    I would smell the vents/fans of the amp. Check the wiring, every inch if you can, to make sure there are now areas of exposed wire. If it didn't pop, it might only slightly be arcing if that's the case.
    Typically, if your under current, the amp should have a safety/protection circuit on it. Some amps even come with LED protection indicator.
    It's more likely it's a exposed wire or possible amp issue than wire size issue.
    Feb 2006
    Orange County, NY
    always dirty
    ^^^I agree. 8 gauge should be able to handle 30 amps fine. If you feel the wires are they hot? Make sure the ground has a good clean connection.
    Omaha
    Yeah the sub was working, but it is a pretty old amp, it was my brother in laws when he was in high school. I opened up the amp and took a look at the circuit board and there were some burn type marks on the circuit board so I'm guessing the amp is just shot.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    If it smells bad too, I'd say so.
  1. Question: Anyone know anything about wiring an amp?
    By noxside in forum Stereo and Electronics
    Last Post: 09-15-2008, 06:55 PM
  2. NEED 1/0 wiring kit
    By claytonr in forum Stereo and Electronics
    Last Post: 02-19-2008, 04:50 PM
  3. NEED 1/0 wiring kit
    By claytonr in forum Parts Wanted / Trade
    Last Post: 02-19-2008, 09:46 AM
  4. Replies: 1
    Last Post: 11-16-2007, 09:41 AM
  5. Ftp Wiring Help!!
    By rx7nam in forum General Help
    Last Post: 06-22-2007, 02:32 PM
