Results 1 to 15 of 15
Thread: adjusting my konis
04-13-2011, 05:32 PM #1
adjusting my konis
How should I set my koni shocks in the rear for maximum traction off the line? I've got a full aftermarket rear suspension. Right now I have all 4 set roughly in the middle.
04-20-2011, 08:08 AM #2
Damn nobody huh? WTF are u guys that have konis set at? Full soft in the rear or what?
04-20-2011, 08:22 AM #3
Calm down
and wait a minute...
04-20-2011, 08:24 AM #4
04-20-2011, 10:59 AM #5Member
- Apr 2009
- Pennsylvania
Pewter- 2000 Camaro SS
04-20-2011, 11:25 AM #6
You would want soft in the rear and firmer up front.
The object is to transfer weight to the rear on launch. Soft in the rear would allow the rear to squat, planting more weight on the rear tires, hence more traction.
04-20-2011, 12:12 PM #7
That's what a was thinking,Ty Jon you are really earning that tech team badge
04-20-2011, 05:19 PM #8Member
- May 2009
- Central Florida
red- 2000 Z28
Unless you're running double adjustable Koni's, you can't control compression. Up front I'd go soft to get the front end up which will aid weight transfer by allowing the shocks to extend faster.
Sent from my DROID2 using Tapatalk
04-20-2011, 07:22 PM #9
04-20-2011, 07:40 PM #10
04-20-2011, 09:13 PM #11
04-20-2011, 11:59 PM #12
04-21-2011, 08:27 AM #13
Wow just ran it last night with my shocks set in the middle......2.7 sec 60ft time,had to let off and roll then floor it again......14.5 at 105 mph wtf
04-21-2011, 08:44 AM #14
Mine are set at full soft in the rear and 3 sweeps away from full soft in the front. I cut a 1.9X 60' (I'm a M6) and a 13.1 @ 108MPH and I only have LT's/exhaust/lid for mods.
Do you have times before the shocks? Are you lowered? Do you have lower control arms and relocation brackets? If you are lowered, did you adjust your pinion angle on your torque arm to compensate? That is assuming you have an adjustable torque arm.
04-21-2011, 08:52 AM #15
I am on stranos,full umi rear suspension and every piece is adjustable,brackets,and my pinion angle is -2,I ran 13.2 about a yr ago b4 headers and suspension,the track felt slick,very slick
Konis came in today.
By Naaman in forum Suspension and HandlingReplies: 28Last Post: 10-15-2017, 05:18 PM -
Anyone run Sportlines with Konis ??????
By 5abivt in forum Suspension and HandlingReplies: 6Last Post: 02-27-2010, 12:32 PM -
Question: what are your konis set at
By nuttyprofessor in forum Suspension and HandlingReplies: 1Last Post: 03-30-2008, 10:27 AM -
differences in the Konis
By nuttyprofessor in forum Suspension and HandlingReplies: 5Last Post: 01-16-2008, 12:26 PM -
Konis On Ebay
By Mr. Anderson in forum Suspension and HandlingReplies: 5Last Post: 08-15-2007, 04:54 AM
