Results 1 to 2 of 2
Thread: what are your konis set at
03-28-2008, 06:24 PM #1
this might have come up before but i am too dam drunk to do a search.....what are your street settings with your koni 4/4 shocks/struts? also what did you use to compensate the rear springs if you put the fronts on the lower spring perch? 3/4 inch heater hose as spring cups??
03-30-2008, 10:27 AM #2
I only have the Koni DA's in the front and Bilsteins in the rear.
I have the compression set at 6 and the rebound set at 4.
adjusting my konis
By bpopham22 in forum Suspension and HandlingReplies: 14Last Post: 04-21-2011, 08:52 AM -
Anyone run Sportlines with Konis ??????
By 5abivt in forum Suspension and HandlingReplies: 6Last Post: 02-27-2010, 12:32 PM -
Question: Konis... How long will they last???
By architect7 in forum Suspension and HandlingReplies: 4Last Post: 06-02-2008, 01:57 PM -
Konis backorder
By wickedWS6 in forum Suspension and HandlingReplies: 35Last Post: 04-16-2008, 08:32 AM -
Konis Fitment
By GUSHER in forum Suspension and HandlingReplies: 1Last Post: 07-20-2007, 11:35 AM
