Thread: Monsoon HU Replaced.
04-10-2011, 08:10 PM #1Junior Member
- Jan 2007
- loveland, colorado
black- 1999 trans am ws6
Finally finished installing Pioneer MVH-8200BT with the steering wheel adapter. In searching on this forum and the quote I got from Car Toys, I came across that the tweeters for the Firebird had to be wired up separatly to get to work. I found that to not be the case. My tweeters work fine with the HU and the wiring adapter from Crutchfield. While I was reading over the wiring instructions from the adaptor and looking at the plug in the dash, there are four sets of wires on the plug in the dash. This tells me (and I may still be wrong or not have an actual monsoon system) that the tweeters are powered by the amp and not the head unit. Anyone that has insight on this please speak up, it would help put my mind at ease a bit.
If this has already been covered and proved either way, let me know and where to find. Thanks.
04-11-2011, 03:49 PM #2Senior Member
- Feb 2006
- Orange County, NY
The tweeters are powered by the hu. The 6.5 speakers are powered by the amp. As you found out all you have to do is wire it up like you dont have the monsoon. Every speaker works correct?
04-12-2011, 09:06 AM #3Junior Member
- Jan 2007
Yes, every speaker works. Just wanting to have a better understanding of the wiring when it comes time to replace the speakers, if I didn't go the Kee Audio route.
04-12-2011, 11:38 AM #4Senior Member
- Feb 2006
- Orange County, NY
The big thing with the speakers is the impedance. The woofers are 2 ohm with the rears being dual voice coil 2 ohm. The tweeters are basic 4 ohm. If you replaced the speakers too the best option is just choose what you like and bypass the monsoon amp.
04-12-2011, 12:13 PM #5Junior Member
- Jan 2007
Thanks for the advice. Just to get it straight in my head: The tweeters are 4 ohms, the 6.5's in the doors are 2 ohms, the speakers in the panels are dual voice coil 2 ohms, and the 4" in the back are 4 ohms?
04-12-2011, 12:41 PM #6Senior Member
- Feb 2006
- Orange County, NY
Yes. That is why most people replace everything.
04-13-2011, 02:56 PM #7Junior Member
- Jan 2007
Thanks. This info helps quite a bit.
04-22-2011, 04:59 AM #8Junior Member
- Phoenix
LMB- 2007 Z06
I replaced some of mine - ended up swapping the whole system. The monsoon isn't really compatible with anything...
Ever Replaced the...
By Smkn_TA in forum Firebird / WS6Replies: 5Last Post: 09-29-2008, 12:34 PM -
Who else has replaced their factory Monsoon speakers?
By SiggyZ in forum Stereo and ElectronicsReplies: 1Last Post: 02-05-2008, 10:34 AM -
non monsoon headunit in monsoon system....
By ivan1 in forum Stereo and ElectronicsReplies: 2Last Post: 05-04-2007, 06:34 AM -
The SS has been replaced......
By pinky93 in forum Camaro / SSReplies: 40Last Post: 09-15-2006, 12:03 PM
