Thread: Squeeky T-Top Panel...
04-08-2011, 04:41 AM #1
My new to me '02 SS driver side t-top panel squeeks, rattles, whatever you call it. If I hold it it's silent.
How can I silence this monster?
Jon
04-08-2011, 06:18 AM #2
try wiping the gaskets down with silicone dressing.
SteveC
04-08-2011, 06:38 AM #3
So there is no adjustments to be made?
I will give the silicon a try.
Thanks.
Jon
04-09-2011, 01:18 PM #4Electrical Engineer
- Jul 2009
- North of the Motorcity
A squeak can be resolved by the silicon, the silicon will not resolve the rattle though. Your weather stripping might be worn out. Try to locate the area that is specifically rattling, IE near the latching pins, and try to tighten up the screws near it. Otherwise, there isn't any sort of adjustment you can do.
04-09-2011, 02:59 PM #511 years of bangin gears
- Jan 2009
- North Jersey
Agree with all of the above stated.
04-10-2011, 05:30 AM #6
Thanks all!
Jon
04-10-2011, 07:03 AM #7
I've had to fix this on my T-tops. Take the top off and lay it upside down on some carpet or a towel. There is a retaining clip behind the handle that needs to be removed. Once that is off pull the handle up and set aside. Remove the two Phillips head screws on both ends (where the rods hold the tops on) and the whole plastic piece will now come off. Put anti-seize on all the hinges and you should be quiet for a long time. I bought my 2002 new and have had to do it twice.
04-10-2011, 03:26 PM #8Senior Member
- Apr 2007
- Newport, RI
Navy Blue Metallic- '00 Formy A4
I read on anotherforum where someone did a write up on this. IIRC, what they did was remove the roof panel, and then the plastic trim piece on the A pillar where the top pin slides into it. After removing the plastic piece, he was able to bend the metal piece that the pin slides into toward the rear of the car, to make the top fit tighter. After that he said the rattle was gone.
Not sure if it works, I haven't tried it, but it's easy enough to try.
Help: squeeky annoying noise..
By Lunatikgixxer in forum Firebird / WS6Replies: 18Last Post: 09-03-2010, 07:35 PM -
Squeeky Pads
By JoshieDoom in forum General HelpReplies: 14Last Post: 02-24-2008, 09:10 PM -
squeeky pulley...
By rajiv1998 in forum General HelpReplies: 1Last Post: 08-29-2007, 06:42 PM -
Squeeky Passenger Seat
By dougcw in forum General HelpReplies: 4Last Post: 11-12-2006, 08:46 PM -
Squeeky squeeky squeeky!!!
By f16z28 in forum External EngineReplies: 10Last Post: 11-10-2005, 11:01 AM
