    Member Fran D's Avatar
    Washington Crossing, PA
    Question For those of you who have puked their Torsen...
    ...what kind of indication did you have? Presently, I don't seem to have any kind of "posi" capability at all. It looks to be operating like an open-end rear. I have picked up a hellacious whine from it as well.
    I'm asking if anyone had a similar failure manisfestation to see if I have "failed-safe" or whether I should expect this thing to lock up at some point while I'm running 70 MPH on the highway. It's my daily driver.
    Thanks in advance.
    nocoloc02z
    Guest
    well im so far on my sencod torsen diff.the 1st time i ran stock 342 gears now im running richmond 410 s .im for sure with 400 rwhp it will break again so im babyin it.expect a 7.5 10 bolt to come apart with even an eaton diff
    Quote Originally Posted by nocoloc02z
    ...expect a 7.5 10 bolt to come apart with even an eaton diff
    Oh, I'd expect it to come apart after a while. I was just looking for some quick diagnosis tips that didn't require removing the cover.
    As it turns out, I did remove the cover to find that the diff is probably OK. All the posi gears are intact and there is no visible signs of fracture on the case (at least for those areas that are visible). The backlash, however, has opened up to as much as 0.017" in some places. It looks like the left carrier bearing is wearing away, which is allowing the carrier to wobble (hence, the backlash) and casuing the howl I'm getting (sounds a lot like tire noise, but the sound remains with the tires off the ground). A good amount of metal was on the magnet (pretty worn ring gear), but it wasn't chunky and it didn't cover the magnet completely.
    I still need to drive this thing for a while before I can fix it. I'm just hoping it holds together long enough before it blows and actually wounds the carrier.
    Here and there
    2001 Z28
    Thumbs up
    Quote Originally Posted by Fran D
    Replace the carrier bearings. ASAP--Puller to get them off, press to put them on. Hell you can even put them in the oven and drop (tap) them on. Don't let bearings destroy the R.G etc..
  1. Zexel torsen 3.73s
    By Supersport0126 in forum Drivetrain
    Last Post: 01-25-2012, 02:30 PM
  2. Help! Rocker arm puked, what to do??
    By I love toys in forum General Help
    Last Post: 04-27-2010, 09:14 AM
  3. Damn You Torsen!!
    By TheGimp711 in forum Drivetrain
    Last Post: 04-30-2008, 08:21 AM
  4. Battery puked
    By Trolleyman in forum Western Members
    Last Post: 03-15-2007, 03:17 PM
  5. Torsen or Posi
    By 9t8z28 in forum Drivetrain
    Last Post: 01-03-2007, 04:42 AM
