Results 1 to 3 of 3
    Aug 2011
    pittsburgh,pa
    navy blue
    1998 camaro ss
    Zexel torsen 3.73s
    was looking in a slp mag. About some zexel torsen (i think there called) gears for my ss. Is anyone familiar with their strength and durability? And do I need that little slp speed control/a Idjustment box?
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    Quote Originally Posted by Supersport0126 View Post
    Zexel torsen refers to the actual posi unit that is in the rear end the ring and pinion gears bolt to it and to the housing. The torsen unit howveer does use tiny internal worm gears inside itself to lock the differential to make it spin both tires however the actual rear end ratio gears are something completely different. Since you have a 98 you do not have the torsen differential 98 cars came with an auburn posi unit which uses clutches to lock the tires together. This is a zexel torsen differential with the big gear (ring gear) bolted to it. the auburn which is in your car is the next one down.2ajvno5.jpg Auburn differential 75 10 bolt image by RATExOFxFIRE on Photobucket
    Aug 2011
    pittsburgh,pa
    navy blue
    1998 camaro ss
    Thanks a lot man
  1. WTB zexel 3 series differential
    By david_viny in forum Parts Wanted / Trade
    Last Post: 06-25-2009, 07:27 PM
  2. zexel-torson or auburn
    By twozs in forum Drivetrain
    Last Post: 03-04-2009, 05:02 AM
  3. Zexel-Torsen Differential
    By RE98TA08 in forum Parts For Sale / Trade
    Last Post: 10-15-2007, 03:44 PM
  4. WTB: 99+ LS1 rear with Zexel-Torsen Diff 3.42
    By jagevileye21 in forum Parts Wanted / Trade
    Last Post: 03-16-2007, 06:20 PM
  5. Zexel HD or Eaton Posi
    By 99M6Z28 in forum Drivetrain
    Last Post: 07-27-2006, 04:29 PM
