    Feb 2006
    Orlando FL
    Barbados Blue
    2004 Pontiac GTO
    Turbo/Super charger Intake Temp without air cooler. 5-6 psi
    I am fianly getting around to really tuning my car with the sts turbo kit runing only 5 psi and no inter cooler I am seeing max of 156F max IAT Temp I was wondering whats this compares to on a blower car with no cooler or a aftercooler thats runing with out ICE. My procharger kit was runing like 200F after a hard run with no cooler. So I am very impressed that this turbo kit is around the 130-140F with out a cooler. SO the real truth is car does not even need tuning if u bolt the kit on and run has long has u have big enough injectors the car run with stock fuel and timing trim will run fine on the 5 PSI.
    I am thinkging intercooler will drop the temps to 120F max and down.
    Member tici's Avatar
    Zurich - Switzerland
    1998 M6 vert TA
    in summer, with 85F outside air it goes up to 180F at WOT with 5-6 PSI.
    This is a non intercooled Vortech.
    I added a water-alcohol injection: now I don't see higher than 80F (also in summer)
    MODS: A4 > M6 conversion, SC raptor hood, Vortech V9 G-Trim SQ, homemade water-alcohol injection
    DYNO: 410 RWHP, 417 TORQUE @ 5 PSI
    Feb 2006
    Orlando FL
    Barbados Blue
    2004 Pontiac GTO
    Quote Originally Posted by tici
    Thats great did you see big hp gain when you got the temps to 80F.
    Thanks for the info.
    Any body eles please give me your temp info blower or turbo.
    1998 M6 vert TA
    +30 RWHP
    17* timing, 12.5:1 AFR, 0 KR
    I run 50% ethanol, 6 GPH@100 PSI, injection starting from 1 PSI
    Member ericwilloughby's Avatar
    Louisville KY
    Yellow
    2005 GTO
    Where does the meth inj dump it's fuel?
    1998 M6 vert TA
  1. Question: Super charger on my 3.8 firebird
    By izzhemp in forum Firebird / WS6
    Last Post: 09-12-2011, 07:46 PM
  2. Oil Cooler and Temp Gauge Install
    By Frozen WS6 in forum External Engine
    Last Post: 05-14-2011, 08:56 AM
  3. 05 c6 super charger hp nu
    By chad35 in forum Forced Induction
    Last Post: 06-11-2008, 10:46 AM
  4. Super Charger Question
    By RYDER661 in forum Forced Induction
    Last Post: 07-20-2006, 07:45 PM
  5. Super Charger needed
    By derekws6 in forum Parts Wanted / Trade
    Last Post: 03-14-2006, 11:37 AM
