    Junior Member JROBINSON1016's Avatar
    NORTH CAROLINA
    RED
    1998 TRANS AM
    headlight troubles
    i'm having troubles with my headlights....
    wondering what could be causing this
    i noticed my headlights seem to be dimming,low visibility
    none are burned out
    was driving down the road one night, with my brights on, i noticed suddenly it was like they got brighter
    didnt think much about it, later on when i switched back off of bright, that they were really dim,so next stop sign i jumped out, i noticed all 4 lights were on on dim,so i clicked on the brights, only one was on, clicked em again & they went back to 2 lights on dim so i rolled on
    very strange....
    any ideas?
    isnt there some kind of headlight control module, or maybe switch related?
    please help!!!!
    Greene, Iowa
    99 Chevrolet Camaro Z-28
    being as you have a bird, and pop ups i would look at the wiring to see if maybe a couple of wires possibly got wore thru and are grounding out on each other or possibly the car somewhere...thats really weird symptoms your having...maybe pull the headlight relay and check it for corrosion too?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    How old are the bulbs? They could be going bad as well.
    phoenix
    04 2500 4x4 crew cab
    Unplug the connector for the lights.(They are under each set of headlights.)You'll have to remove the bezel and pop up the headlights. Manually raising the headlights is safer. I just turned mine on to pop them up, they didn't close when I unplugged the connector. Then reconnect them. I had to do this a couple of times, then no more problem.
    NORTH CAROLINA
    RED
    1998 TRANS AM
    seemed to be an issue with the connector under the headlight assembly
    i wiggled it a little & they straightened right out
    guess its just a bad or loose connection in there
    maybe corrosion
    not sure really
    any ideas on how to fix this permanently?
    phoenix
    Replace it. It seems like the wires are too small. Cna't carry the voltage. You could go HID. that would replace all that wiring. Probably only cost you a little more than rpalcing wiring and pigtails.
  1. ABS troubles
    By spyhunt3r in forum General Help
    Last Post: 10-01-2013, 06:51 PM
  2. Turkey troubles
    By LimeNine in forum Almost Anything Goes
    Last Post: 02-09-2013, 01:38 AM
  3. bit of troubles from the start !
    By Dennis Larkin in forum General Help
    Last Post: 09-30-2011, 07:05 PM
  4. Oil troubles/with vibrating
    By RedHot99T/A in forum Firebird / WS6
    Last Post: 10-12-2010, 05:21 PM
  5. t-top troubles...
    By delinquent543 in forum Firebird / WS6
    Last Post: 11-09-2005, 04:11 AM
