Results 1 to 10 of 10
    Member RedHot99T/A's Avatar
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    Oil troubles/with vibrating
    Ok so i posted awhile ago about a couple problems ive been having..i have alot more information now.I had a misfire in cylinder 3 changed the coil and wire,then i took out the plug to replace it with a new iridium plug,and the year old plug has oil in the threads and a lil on the plug itsself,so i replaced it and it misfired more than the old plug,but went away a day later...what could cause the oil on the plug(s)?and im also have a very noticable vibration thru the shifter thru the whole rpm range and also slightly at idle,when i did the clutch Napa resurfaced the flywheel...could this be the problem?i also know i need an alighnment which is what my dad tells me the proble could be.So what do you all think?ik its hard to help with problems like this without actually driving the car.but any help it awsome.
    You may be getting excess oil in the intake from the PCV system. Did you pull any other plugs by chance?
    The factory service manual warns against re-surfacing the flywheel as it has a taper. That being said, I know of at least one other member that has done so without any apparent issues. Could it be a u-joint on its way out? How about a broken trans mount?
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    plug 3 is the only one with oil on it,and idk how to check a bad ujoint,ik there is no play with the driveshaft and the mount is fine that was my first guess
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    Quote Originally Posted by RedHot99T/A View Post
    if plug 3 is oiled up, it could be bad rings on that piston....hopefullly not....also, i dont know if it applies to ls1, but on the 3.8 with the plastic intake, it cracks after time and begins to leak into the cylinders...
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    Quote Originally Posted by jiveass View Post
    Good point with the intake,my friend had his crack on the ls1....it does have 130000miles on it,and I'm sure about all of them were hard miles.I try to baby it but still have fun.
    Oct 2009
    pewter
    99 trans am
    sometimes you gotta feed a little speed to your ride....keeps the engine clean
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    o deff.dont go crazy on my car but she deff doesnt get driven to soft...lol
    Jul 2010
    Albany,NY
    1999 Trans Am ws.6
    I also forgot to mention when let off the gas and the deaccelerates at low speeds in a low gear I hear a whining noise
    Oct 2009
    pewter
    99 trans am
    thats pretty common too as the rear end is a pos in these cars
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Not a problem with the LS1 intake. There isn't any coolant flow through the LS1 intake like the 3.8
  1. Vibrating Drivers Mirror
    By CamaroFan71 in forum General Help
    Last Post: 08-20-2008, 08:40 AM
  2. Will poly mounts cause vibrating.
    By Street Fighter in forum Suspension and Handling
    Last Post: 05-16-2008, 06:15 PM
  3. Engine vibrating?
    By Street Fighter in forum Internal Engine
    Last Post: 04-08-2008, 06:45 PM
  4. Vibrating speaker?
    By LgndKller20073 in forum Stereo and Electronics
    Last Post: 09-26-2007, 01:30 PM
  5. Vibrating at feet. (98 z28)
    By nerd4life in forum External Engine
    Last Post: 10-08-2006, 05:16 PM
