Results 1 to 19 of 19
Thread: Throttle body
03-08-2011, 06:14 PM #1
Throttle body
The guy tuning my car does port work and swears I should do my tb. He said it would be one of the best 100s I could spend
03-08-2011, 06:17 PM #2
03-08-2011, 06:27 PM #3
He'll yea I think I will it's just with this head and cam I got a street tune and had to take wot for the logs and my clutch said nossir. Didn't go out I thinks it's the slave cylindar cuz it's just sticks for a sec when at full throttle and with said Im getting a twin disc and labor and all is around 1100 then I need a rear so every 100 counts lol
03-08-2011, 06:31 PM #4
03-08-2011, 07:14 PM #5
Yea I changed the fluid already but no drill mod. I would love to put that money in the rear. The info is much appreciated.
03-08-2011, 08:19 PM #6Senior Member
- Oct 2008
- Coral Springs, Fl
always happy to help
03-08-2011, 09:03 PM #7Junior Member
- Dec 2010
- slc UT
black on black- 2000 ws6
lost in ls1 options
I have a 2000 ws6 is the BBK 80MM manifold worth the $800.00 i dont see many people with them or talking about getting them just the stock newer GM ones HELP
03-08-2011, 09:13 PM #8
03-09-2011, 05:43 AM #9
03-09-2011, 06:44 AM #10
03-09-2011, 06:46 AM #11
03-09-2011, 06:50 AM #12
03-10-2011, 07:46 PM #13Junior Member
- Dec 2010
- slc UT
ls6 manifolds
THANKS for the info TATERTO91 AND CUTLASS I have been trying to learn more on picking the right manifold and talked to a guy at LMPerformance and he agreed with you guys And pointed me towards the LS6 manifold. Now the ? How much more gain over my LS1 and is it worth doing on a daily driver
03-10-2011, 07:55 PM #14Senior Member
- Apr 2008
- Madison, WI
I can't exactly remember the gains of an LS6 intake on a stockish engine. But I do remember feeling a difference. And the more you mod, the more your LS6 intake will help you.
03-10-2011, 09:56 PM #15Senior Member
- Oct 2008
- Coral Springs, Fl
Dyno wise its about ~15hp over stock
Just make sure if you buy one you make sure the bottom is flat, i've seen people try and sell corvette ls1 intakes off as ls6 ones since they have no EGR and look similar. Easiest way to tell is to make sure the bottom of the intake is flat.
Also for that swap you need the LS6 style coolant tubes. The LS1 style runs a tube across the bottom of the intake, The LS6 style runs across the front on the heads and has plugs for the rear.
03-11-2011, 03:34 AM #16;)
- Apr 2001
- Surf City, NC
Black/Screaming Yellow- 99 S/C TA WS6 & 04 Cobra
Don't port your stock one. Just buy a new one with a different intake like was suggested already. I have seen too many stock ones get self-ported or ported these so called masters and it makes the car virtually un-tuneable sometimes with addition of new mods such as heads/cam. What happens is with the stock components and mild set-up of bolt-ons its fine. Then add the Heads/cam/intake where there is a need for more air/fuel. That is where the problem arises from bad port jobs and idling problems that people associate with the cam and tuning but in reality it comes from the tb being half-assed ported and wierd things being drilled or ground out of the stocker. Plus people sometimes take the blade out and mess with that too. Big no no! It will never be the same after the blade has been drilled or modified.
The only thing you should ever do to your stocker IMHO is the bumpstop grind to ensure the blade is open all of the way at WOT. Other than that leave them alone and just buy an aftermarket one that is professionally made.1999 Trans Am WS6 Black - Forged 346, P1SC (8psi), TH-400, and 12 bolt(3.73's)
10.29@129 w/1.60 sixty foot
2004 Screaming Yellow Mustang Cobra - Whipple 2.3, Exhaust, & CCW's...My DD
03-14-2011, 06:54 PM #17Junior Member
- Dec 2010
- slc UT
Hey guys is the SLP mass air flow worth the upgrade on the stock manifold with just exhaust chip and SLP air intake ??
03-14-2011, 07:34 PM #18
03-15-2011, 05:50 PM #19
Wanted: LS1 Throttle Body
By the951racer in forum Parts Wanted / TradeReplies: 6Last Post: 08-08-2013, 06:11 AM -
Question: used ls6 throttle body
By CHEVY211 in forum External EngineReplies: 3Last Post: 01-25-2012, 07:24 PM -
Question: Throttle body
By 98maro in forum General HelpReplies: 21Last Post: 03-08-2010, 05:41 PM -
Throttle body ?
By Johns00Z28 in forum External EngineReplies: 9Last Post: 05-07-2008, 10:59 AM -
98-02 stock LS1 f-body throttle body
By noblesramair in forum Parts Wanted / TradeReplies: 2Last Post: 03-04-2006, 06:59 PM
meant for that last post to go to scott
