Results 1 to 10 of 10
Thread: Throttle body ?
04-03-2008, 04:35 PM #1
Throttle body ?
I have a 2000 Z28 and picked up a ported TB. Since then I found out that they switched to a different one somewhere in mid-2000. I want to make sure I have the right one so my question is, would there be any other way to find out other than taking mine off and comparing it to the ported one? And if it is different, is there a way to make it work or will I just have to get rid of it and get mine ported?
04-04-2008, 01:15 AM #215 sec. Oh yeah, its fast
- Apr 2007
- Forest Lake, MN
maroon- 2000 Z28
Are you talking about the mm size cause they all were the same from 98-02.
04-04-2008, 10:23 AM #3
They all should be the same size. Earlier years had a different throttle cam so it opened faster, the correct one for your year should have a blue spring on it.
04-07-2008, 09:10 AM #4
Yeah I'm talking about the throttle cam. I just brought mine down to the car and compared it to the one on there and the one on my car is noticably bigger so I guess I have the wrong one. Damn! I wish I would have known this before I bought it.
04-09-2008, 05:32 PM #5
I could have sworn I read somewhere that we (2000 model year) could use the 98-99 version, but they just couldn't use one off of ours because the cable would be too short....
Can anyone confirm?2019 Silverado LT Z71 5.3, 8L90E
2000 Pontiac Trans Am WS6 6.0, 4L80E, 9" rear, TURBO...
9.32@147
04-10-2008, 09:03 AM #6
you can adjust the throttle cable on a 00-02 car to use a 98-99 TB, i am not sure where this adjustment is
a 98-99 car can drill a new hole on the cam lobe to use the 00-02 TBM6, Lid, Ported and Polished Throttle Body (By Me!), LT, Custom Catted Y, Electric Cutout, PHB, LCA13.21@108 with a 2.3 60'
04-10-2008, 10:06 AM #7Member
- Jun 2007
- Dalzell, Illinois
red with black stripes- 2002 Trans Am WS6
the throttle body i got from summit came with different cams for it. It had the bigger one for the newer and smaller for the older. it came with a spacer to fit on the ls6 intake so i had to use the smaller cam with the spacer.
04-12-2008, 05:10 PM #8Junior Member
- Feb 2006
- GARDEN GROVE, CA
BLACK- 2002, CAMARO Z28
Just transfer the cam and spring from one to another.
04-24-2008, 09:11 PM #9
05-07-2008, 09:59 AM #10
Just for an update. My mechanic friend was able to adjust the cable so it did end up working out. Thanks for your suggestions.
Wanted: LS1 Throttle Body
By the951racer in forum Parts Wanted / TradeReplies: 6Last Post: 08-08-2013, 05:11 AM -
Question: used ls6 throttle body
By CHEVY211 in forum External EngineReplies: 3Last Post: 01-25-2012, 06:24 PM -
Question: Throttle body
By 98maro in forum General HelpReplies: 21Last Post: 03-08-2010, 04:41 PM -
throttle body
By BLAUPLOW in forum External EngineReplies: 2Last Post: 02-16-2009, 04:24 AM -
98-02 stock LS1 f-body throttle body
By noblesramair in forum Parts Wanted / TradeReplies: 2Last Post: 03-04-2006, 05:59 PM
