Results 1 to 17 of 17
02-23-2011, 10:32 AM #1Junior Member
- Dec 2010
- Louisiana
- 02 WS6 Stock
Half my gauges not working, half the warning lights lit up!
Got in my car this morning after work and only half my gauges are working, half the warning lights are on and the OBD port doesn't work.
Traction control button is not lit and not working. Seatbelt and SES light are operable (SES light came on after i took off driving because of a malfunctioning knock sensor).
I checked all fuses on the side of the dash and all of them under the hood with a DMM and they all tested good.
What should i check next?
02-23-2011, 11:21 AM #2O U 8 1 2
- Nov 1999
- over here...
got any friends with a PCM that you could swap with the see if it's the PCM shitting out on you???
02-23-2011, 11:32 AM #3Junior Member
- Dec 2010
- Louisiana
- 02 WS6 Stock
I just finished plugging my PCM back in. It had a bit of water and some corrosion in the top side. I cleaned it as best I could and dried everything with a hairdryer on med.
Just fired it up and everything seems back to normal. Except of course for the piston slap. Haha.
Thanks for the reply!
02-23-2011, 11:34 AM #4
02-23-2011, 11:52 AM #5Senior Member
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
my guess on why it got so wet is possibly the weather stripping on that black cowl piece around the base of the windshield/ wiper area could be torn, or even missing?
02-23-2011, 02:17 PM #6Junior Member
- Dec 2010
- Louisiana
- 02 WS6 Stock
The weather strip on the cowl is intact and fine. I did wash my engine with the garden hose last Saturday. I wrapped the PCM with a trash bag really good then i was careful not to spray any water it's way.
Maybe when i was drying the motor off with my 150mph leaf blower it blew some water into it. The trash bag had some water on it when i took it off. I was careful not to spray directly in front/back of the intake manifold but i somehow got water into the knock sensors so i have to replace them.
I don't think i'll be using a garden hose to wash my engine again!
If you ever have to remove the PCM or it's connectors, the rubber gasket goes IN THE CONNECTOR. When i pulled my connectors off, the seals were left on the PCM so that's how i tried putting them back on....for 30 mins.
02-23-2011, 05:34 PM #7Junior Member
- Dec 2010
- Louisiana
- 02 WS6 Stock
Well, i guess i spoke too soon. Just went on another ride and the gauges and OBD starting going erratic then they just went out.
I stopped at auto zone and picked up a can of electrical contact cleaner and some soft wire brushes. Hopefully that'll clean it up.
-A little side story: I was at the counter telling the guy i needed the exhaust gasket between the manifold and exhaust pipe for my GF's car and there was this Master ASE Certified meth head with sores all over his face besides me. He says "oh, what you need a sensor? It's the oxygen sensor!" I said, no i need an exhaust gasket. He says, "oh man, you don't need that, get some of that high temperature sealant, put it in there and smash it together. You'll be good to go." I said, this is $1.99 i'll take a chance with this. God, i hate (most) people.
02-23-2011, 07:13 PM #8Junior Member
- Dec 2010
- Louisiana
- 02 WS6 Stock
Brushed it lightly with a brass brush and sprayed some cleaner in it. I guess they were corroded worse than i thought. There was one bent and i went to bend it back in place and it pretty much broke clean off.
I paid for another PCM last week but the guy hasn't responded since payment. Hopefully i get it soon but then i still have to send it off to get programmed. I'm gonna run it like this till i get my new one in and hope nothing blows up.
02-23-2011, 07:30 PM #9
02-23-2011, 07:35 PM #10Junior Member
- Dec 2010
- Louisiana
- 02 WS6 Stock
02-23-2011, 07:40 PM #11
02-23-2011, 07:42 PM #12Junior Member
- Dec 2010
- Louisiana
- 02 WS6 Stock
It's just that one spot, the upper right connector. Everything else is fine. There's a TSB out that says to change the gasket if you ever remove the connectors.
02-24-2011, 07:08 AM #13
02-24-2011, 07:32 AM #14Junior Member
- Dec 2010
- Louisiana
- 02 WS6 Stock
Just put it back together. Car won't start now.
I ordered the gaskets. $30 shipped!
02-24-2011, 07:38 AM #15
02-24-2011, 07:45 AM #16Junior Member
- Dec 2010
- Louisiana
- 02 WS6 Stock
02-24-2011, 10:17 AM #17
that sucks man.
G4: Two guys and a day and a half...
By pajeff02 in forum Almost Anything GoesReplies: 25Last Post: 11-30-2012, 03:16 AM -
97 half ton
By zeetwentyeight in forum GM TrucksReplies: 7Last Post: 06-29-2010, 09:13 AM -
autometer gauges? Are they half decent?
By 2klude in forum NitrousReplies: 6Last Post: 04-10-2007, 04:04 PM -
Robert Half
By SATXBlackSS in forum Almost Anything GoesReplies: 8Last Post: 06-29-2006, 12:50 PM -
din and a half headunit
By sixgunsuperman99 in forum Stereo and ElectronicsReplies: 14Last Post: 10-13-2005, 11:17 AM
