Thread: 97 half ton
    Member zeetwentyeight's Avatar
    Aug 2009
    A, A
    1998 Camaro Z28
    97 half ton
    Anybody know of any free mods for a 1997 chev k1500 with the 350 vortech?
    Its the automatic
    Member IH8EVRY1's Avatar
    Apr 2010
    Savannah, GA
    Subscribed! Or anywhere links to sites that mod these trucks?
    Junior Member MICopper11's Avatar
    St. Charles, Michigan
    Fullsizechevy.com is a great site to check out. I'm a member there with my truck.
    Big Gulps, huh? HOBS's Avatar
    Idaho
    1999 Trans Am
    Quote Originally Posted by zeetwentyeight View Post
    Anybody know of any free mods for a 1997 chev k1500 with the 350 vortec?
    Its the automatic
    Fixed and subscribed.
    Member rel3rd's Avatar
    Baltimore, MD.
    Bright Red
    2000 Pontiac Trans Am WS6
    Thumbs up
    Its the automatic
    Before my 2002 Z71 (4wd) Silverado, I had a 2wd 97 extended cab/short bed Silverado. It was a great truck that served me well...so well, that I regret not keeping it and giving it to my son when he got his license.
    Don't know of any "free" mods unfortunately, although there may be some listed on fullsizechevy or performancetrucks sites? I'd imagine you can modify the stock airbox just like I did to my 2002. It works GREAT and cost nothing but a half hour's time with a cutoff wheel. I cut the bottom of my stock airbox out so that it got cooler (and more) air from between the bumper and inner fenderwell.
    Here is link to see picture, just scroll down to last reply:
    http://performancetrucks.net/forums/...d.php?t=455345
    Anyway, mine responded well to just a few fairly cheap and simple, "cookie cutter" mods.
    1. K&N cold air intake (FIPK is what they call it, but you can pretty much duplicate it for a LOT cheaper using EBAY)
    2. Dynomax one into two "dual" exhaust
    Without a good way to actually tune the truck, there really isn't many more mods you can do IMHO. Headers would be nice, but probably a little much for the stock PCM to compensate for.
    I tried both a Hypertech Power Programmer III and a JET handheld programmer, BOTH of which are JUNK as far as I am concerned. It ran better STOCK than it did with either of their so-called "performance tunes" in the truck...sadly, 98 is the first year that can be tuned with HPTuners, or any REAL tuning solution, so you're kinda screwed there. You can convert to a newer PCM and use HPTuners to tune with, but I was just looking for a better than stock running truck, and not a race truck. I chose not to spend the time and money doing a PCM swap. With 373's that I had stock, the truck ran great with just an exhaust and CAI. It would keep up with most newer, stock (or near stock) LS powered trucks, and had no problem towing a heavy car and trailer when need be...
    One of the common problems with them is intake gaskets literally blowing out and spewing antifreeze, usually without warning. I had to replace mine at about 135,000 miles, but I've seen them go bad much sooner, and much later, so there seems to not be any specific time this happens...but it WILL happen. Just replace them with the revised GM gaskets and you're good to go.
    Good Luck with it.
    2019 Silverado LT Z71 5.3, 8L90E
    2000 Pontiac Trans Am WS6 6.0, 4L80E, 9" rear, TURBO...
    9.32@147
    Aug 2009
    A, A
    1998 Camaro Z28
    Thanks for the reply, i checked out that picture and isnt that down in the wheel well?
    Wouldnt you get water in there?
    Baltimore, MD.
    Bright Red
    Thumbs up
    No, not at all. The space you see is between the plastic inner fender, and the rear side of the front bumper. Any water is directed down from that plastic fenderwell.
    Aug 2009
    A, A
    1998 Camaro Z28
    Nice and this is off of you 02 im assuming since my box sits more towards that back of the engine bay
  1. Half-Off Special
    Last Post: 11-10-2014, 02:50 AM
  2. Replies: 16
    Last Post: 02-24-2011, 10:17 AM
  3. 7 and a half hours on the ZR1's
    By Benner in forum Wheels and Tires
    Last Post: 01-23-2008, 06:46 PM
  4. 3rd and a half gear???
    By Black Dragon in forum Automatic Transmission
    Last Post: 12-25-2006, 08:18 AM
  5. Robert Half
    By SATXBlackSS in forum Almost Anything Goes
    Last Post: 06-29-2006, 12:50 PM
