Thread: Fast 102 intake
02-11-2011, 08:39 PM #1Junior Member
- Dec 2007
- pembroke, nc
silver & black- 2000 TA 1979 TA
Fast 102 intake
hey guys need some help, will a fast 102 cathedral intake fit on 98 camaro ss heads? also can a bbk aluminum ssi intake be fixed if it is busted inside the port? if so, i have a fast 102 cathedral intake fuel rails and throttle body for sale all new. lol
02-11-2011, 09:22 PM #2Junior Member
- Ohio
The intake will fit on your stock heads, although you will likely lose some power down low. That is a lot of intake for stock heads and cam.
02-12-2011, 11:27 PM #3
depending on what you want to do is the question. yes it will fit... if you plan on doing more mods to it then get the 102. if you plan on putting the intake on and letting that be it id buy a 90 or 92 and save the money.
02-13-2011, 06:11 PM #4
02-14-2011, 07:21 AM #5
02-14-2011, 08:01 AM #6
02-16-2011, 07:32 AM #7Junior Member
- Dec 2007
- pembroke, nc
thanks, sorry i didn't post a reply sooner but I've had the flu
... but, what happened is i had a ticking in my motor. thinking it was a failing lifter i kept driving it for a while. i finally saved up enough to change my lifters rockers and rods and during the install we found my intake was busted or blown inside the port. not thinkin it could be fixed and trying 2 get my car out the shop i went ahead and bought the fast 102 thinking it would help. well, it fixed the busted intake problem but i lost a noticeable amount of power since my bbk 80mm was decked. and also the ticking is still there and i hope someone can explain wat it is. does my cam have a worn lobe? if so, how can i tell and would this cause a lifter to fail or a rocker to keep coming aloose? or can there be another problem i am overlooking. so far i have changed my whole top end other than the cam, and before i go back into it i am going to fix my bbk intake and put it back on until i can find a good set of heads. also if i hav a custom cam, 601/612 lift. not sure on duration., and the lobe is worn, can it be fixed or should i invest in a new one and what kind do you suggest on best sound and power for street/strip?
Fast Intake & N20 Kit..
By Click-6 in forum Western MembersReplies: 11Last Post: 05-31-2009, 08:56 AM -
FAST 90 Intake
By Whiteboycntdnce in forum Parts For Sale / TradeReplies: 5Last Post: 12-12-2008, 10:13 AM -
Wanted: LS6 Intake or Fast 90/90
By chieftransam in forum Parts Wanted / TradeReplies: 1Last Post: 05-14-2008, 09:06 PM -
FAST 90 mm Intake !
By chiws6 in forum Parts For Sale / TradeReplies: 10Last Post: 04-02-2007, 06:22 PM -
LS6 intake or FAST 78mm intake
By SSwt00SS in forum External EngineReplies: 10Last Post: 07-26-2006, 01:50 PM
