    Mar 2009
    Arizona
    2002 SS Camaro
    ls6 valley plate upgrade
    Hi everyone I just got done installing a ls6 valley plate in my 2002 Camaro along with ported heads. But now my oil pressure has dropped down to about 30-35 at idle and only goes up to about 45 when I floor it. Do any of you have any ideas what has happened, bad oil pump maybe?
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    Are you sure you didnt damage the oil pressure sender when removing or installing the intake?
    Mar 2009
    Arizona
    2002 SS Camaro
    Yeah im sure i did not break it i was really careful when i took off the intake and put it one.
    I just did the same and have the same pressure as before.
    Did you make sure you plug and cap both valve covers?
    Are you using a catch can or did you keep the pcv valve?
    Mar 2009
    Arizona
    2002 SS Camaro
    No catch can i changed the pcv valve when i changed the plate. I pluged up the back hole on the drive side in the far back, and the one on hte pasanger side wiht the cap that came with the new valley plate. I also changed the oil sender when i did all this as well.
    Senior Member
    texas
    2000 formula
    what brand of OPSU did ya use?
    Mar 2009
    Arizona
    2002 SS Camaro
    ac declo
    Member TA98's Avatar
    Mar 2009
    Maryland
    whats the benefit of changing to an LS6 valley plate
    COTM July '09
    Annapolis, MD
    BLK/BLK w/CGM Stripes
    2010 Camaro 2SS/M6
    Quote Originally Posted by T/A98 View Post
    Better oil control and you get less oil in the intake/etc
    I like work. It fascinates me. I can sit and look at it for hours.
    My Cardomain Site My Fquick site Custom Installs
  1. Zex Perimeter Plate Install - Stepping Up To The Plate
    Last Post: 06-23-2011, 03:30 PM
  2. Borla No passenger side restrictor plate Vs medium plate
    By Guerrillakilla13 in forum Firebird / WS6
    Last Post: 02-08-2011, 08:22 AM
  3. Pontiac Ident-O Plate & Protect-O Plate History Pr
    Last Post: 07-12-2010, 02:20 PM
  4. Upgrade to a plate kit
    By Fury_786 in forum Nitrous
    Last Post: 02-08-2009, 09:41 AM
  5. Replies: 4
    Last Post: 03-09-2006, 05:01 AM
