Results 1 to 17 of 17
    Member Guerrillakilla13's Avatar
    Feb 2011
    Arizona
    2002 Trans Am WS6
    Borla No passenger side restrictor plate Vs medium plate
    Hey everyone
    I have a 02 WS6 with a Borla catback system. I like the sound of it, but i want it much louder. To be completely honest, the person before me (I just bought this thing less than a year ago) put on the Borla, so i have no idea what size restrictor plate is on the passenger side. I hear sound and feel air coming out of it though, so i know it isn't closed.
    Does anybody know the difference of the volume for a open passenger side plate vs a medium to small sized one?
    PS im new to the community, so hello
    Marylandistan
    2001 Trans Am (sold)
    Why not unbolt the flange and see for yourself? If there's a plate in there remove it.
    Marylandistan
    Ohh and I also have the Borla. There is a slight difference between open and the smaller plates but closing it up altogether makes the biggest difference (in the opposite way). Imo if you really want it louder than close it up altogether and put a cutout in the I pipe, this is what I run now. Much louder with an open cutout in front of the axle under the car. I have a DMH electric valve on it and can open/close it from inside the car. Ohh and welcome.
    Feb 2011
    Arizona
    2002 Trans Am WS6
    Quote Originally Posted by INMY01TA View Post
    I want to, but i don't want to screw up the tips. the drivers side and passenger side are pretty even... thought i might kill off some time and stress by asking too.
    Feb 2011
    Arizona
    2002 Trans Am WS6
    hey Thanks man, and i was considering a electric cutout but i don't know where to get them for this specific borla system. Any tips?
    Would an open cutout have the same volume as no restrictor plate?
    Marylandistan
    Unbolting the flange will not screw up the tips as it bolts back the exact same way. With the cutout I'm talking about putting it in the I pipe, before the axle, under the passenger seat. Doesn't need to be Borla specific there. Yes it will be louder there than an open Borla.
    Feb 2011
    Arizona
    2002 Trans Am WS6
    I just tried unbolting it.. whoever tightened it made it too tight, impossible to loosen. Couldn't do it. I might have to take it in to a shop to do it.
    Sounds like a good idea man. Does it require you to cut part of the borla catback, or can it replace a certain part of the mid pipes?
    Ps I appreciate the help
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    This is what I run in my Borla
    http://www.mccordcg.com/mpp/mpp.htm
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Marylandistan
    Quote Originally Posted by Guerrillakilla13 View Post
    It would go in the I pipe (part of the catback) that runs from the Y pipe to the muffler. Here's a pic from pajeff's car. Ohh and use a longer breaker bar and some PB Blaster on those bolts, they'll come out.
    Bonner Springs, KS
    99 TA
    I have a borla with an electric cut-out as well, but I put my cutout in place of the adjuster plates...I used to drive with the wide open plate, but it got too much unwanted attn after the H&C install, now I can have it closed for daily driving and then open it up when I want to have some fun.
    I use the DMH cutout designed to replace the adjuster plates.
    Also, the first time I tried swapping out the plates, it was a PITA to get the nuts and screws off, had to use some penetrating oil and a breaker bar
    Senior Member
    texas
    2000 formula
    i used no plate when i had stock exhaust manis on.......sounded perfect........when i got the long tubes it was to loud for me so i went back to the medium plate
    Phoenix, AZ
    2000 Trans AM
    I dont know much about exhaust so maybe you guys can teach me a few things. Whats a restrictor plate? I dont plan on upgrading the exhaust until i do a engine swap in a year or 2 but what do you guys recommend?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    The Borla Adjustable cat back system has a single 3 inch pipe coming from the y-pipe. That pipe goes up over the axle and then tees off so you can have dual outlets. One pipe exit each on the drivers and passenger side.
    The drivers exit goes through a muffler. The passenger side is straight trough (no muffler). There's a joint there that you can install a resistor plate to adjust how much exhaust and sound comes out the passenger side. If you completely block it off, all the exhaust goes through the muffler and out the driver's side exit. There's also a plate with like a 1 inch hole and a 2 inch hole and there's the option to not run a plate at all (wide open noise and flow.)
    Feb 2011
    Arizona
    2002 Trans Am WS6
    Thank you man, but i dont have that stuff i'll just have my muffler shop do it. And thanks for the pic, i thought about putting it in the I pipe but I think it would be better just to put it where the passenger restrictor plate is. Putting it in the "I" would just add a third tip, and on the right side only. I don't think it would work right nor make it as loud all around the car as i would want it to be..nor even look right haha.
    Quote Originally Posted by sjsingle1 View Post
    I'm going in to the shop on tuesday or wednesday and i'm gonna have him help me out with the plates and perhaps some advice on where the cutout should go for maximum sound (his idea, not mine). What kind of headers do you have? I was seriously thinking about doing what you did, but the labor for headers are freakin expensive. If i can find good LT headers for a good price, i might do it.
    Quote Originally Posted by peterlawl84 View Post
    How do you like it putting the cutout there? Before the Heads and cam? Would you say its worth it? Damn your car must sound like a beast
    Marylandistan
    It's louder underneath (closer to the engine) shakes the whole car. Don't see it under there either. When you get a bigger cam it lopes harder from there, sounds more stockish coming out the back.
    Bonner Springs, KS
    99 TA
    I like the ability to adjust it from the driver's seat at will now rather than having to get under the car with wrenches. When it was stock, the wide open plate sounded great. After LT, it still sounded great, but was alittle loud and I would have to watch out for cops. After H&C, it was definitely too loud...had cops turning around in traffic to try and follow me.
    I got the cut-out after the H&C, but in hindsight, I would of definitely liked it prior so that I could quiet it down if it was late at night or whenever.
    While I'm sure the cutout in the I pipe might be a tad bit louder, it is definitely loud enough where I have my cutout, plus I have the option of running it with everything going through the muffler (which you can not do if it is in the I pipe).
    Also for those that are curious, I ran the car on the dyno with the cutout open and closed, picked up 6 rwhp and 33 ft/lb torque with it open vs closed.
    Feb 2011
    Arizona
    2002 Trans Am WS6
    INMY01TA, I like the sound of that! But im gonna probably have to do what peterlawl84 said... just put the cutout where my restrictor plate is. It might not be as loud as i want stock, but i do get more control over how much air goes through the muffler (instead of through the passenger side tip) and how much doesn't.
    Alright gentlemen, based on all of your help, i've made a decision. For now, i'm just going to get the restrictor plate removed once I'm due for an oil change (Which'll be pretty soon). During the summer time, when my work gives out tons of hours, i'm going to save up some cash and buy Pacesetter Longtubes with Pacesetter midpipes. Than MAYBE if its too loud, i'll get the cutout.
    Thanks everyone for the help! Great community we got here.
    2014 Camaro: Check. 2SS: Check. 1LE: Check. 6 Speed manual? CHECK
  1. Wanted: looking for the cover plate for passengers side mirror
    By 02silverbird in forum Parts Wanted / Trade
    Last Post: 09-25-2010, 08:48 PM
  2. Pontiac Ident-O Plate & Protect-O Plate History Pr
    Last Post: 07-12-2010, 02:20 PM
  3. Borla Adj Which Plate?
    By SilverSteen25 in forum External Engine
    Last Post: 02-18-2008, 05:37 PM
  4. Borla Plate!!!!! $$$
    By cubicpower89 in forum Parts Wanted / Trade
    Last Post: 06-01-2006, 09:43 PM
  5. Replies: 4
    Last Post: 03-09-2006, 05:01 AM
