Results 1 to 18 of 18
    02 Silver T/A-6 spd Waynestep's Avatar
    Feb 2006
    Reinholds, PA
    2002 Firebird T/A - WS6
    Question Best Tire Treatment?
    Hi-
    I'm relatively new to the forum so this has probably been discussed, but what has anyone found to be the best looking and longest lasting treatment to keep your tires clean and black and shiny?
    I've tried foams, silicones, whatever, and none seem to both last a long time and do a good job.
    Thanks for replies.
    detail king 2001somws6's Avatar
    ORLANDO,FL
    SUNSET ORANGE
    2001 PONTIAC TRANS AM WS6
    the first thing i do is use a rim cleaner to strip everything off the tire and a scrub brush and hose it down. i perfer to use black magic tire shine. with a old applicator and were a glove doing this. that black stuff gets under the nails.
    Member SmokinSS's Avatar
    Lanc. PA
    RED
    1998 Camaro SS Vert
    Meguiars makes a tire gel that works awesome, and lasts for a long time. I just use an applicator pad to apply it, and I first use some type of cleaner like bleach white to clean the tire off. This seems to work great.
    SS-EIAN SSNAKEATER23's Avatar
    CHICAGO
    SILVER
    1999 CAMARO SS
    I use an old shop rag and scrub the tire off then i use a cleaning solvent to get the rest of the tire that i missed. I dont like to use the gel cause it just gunks up all over the tire. I love Black Magic!!!!! Spray it on the applicator and apply evenly over the surface of the tire. If there is too much i wipe off with old rag.
    Feb 2006
    Reinholds, PA
    Thanks a lot guys- I'll be trying your suggestions.
    Feb 2006
    NJ
    I USED TO WORK AT AN AUTO BODY SHOP, AND WE ACTUALLY USED 89 CENT HIGH GLOSS BLACK SPRAY PAINT,BELEIVE IT OR NOT,YOU GOTTA TRY IT.JUST SCRUB THE TIRES REALLY WELL, MASK OFF, THEN SPARY AWAY.
    I Fixed Da Rear jimbo98z's Avatar
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    Meguiars Gold Class Endurance High Gloss Long Lasting Tire Protectant Gel
    Purple, and comes in a clear plastic bottle.
    I typed the whole name becuase Mequiars makes a couple different types, but this is by far, the best. Put it on with an applicator and it will last at least a week, even through rain. Plus it smells like grapes. If you want them to be obscenely shiny, you can put a second coat on after 10 minutes too. I will usually wash the car, put one coat on, dry the car, and then put another coat on.
    I would stay away from any kind of spray on tire shine. It doesn't look as good or stay on as long. It's pretty much the lazy way out.
    1998 Camaro Z28 M6
    SLP Lid, Flowmaster, Cutout, Spec Stage 3, Pro 5.0 w/ Lou's short stick, Pacesetter Race LT's, Drilled/Slotted Rotors, Hawk HPS pads, Nitto NT555R DR's, Moser 12-bolt with TrueTrac and 3.90s, RPM Speed LCA's and Panhard Bar
    Lansing, MI USA
    '99 Z28
    Quote Originally Posted by trans-am nut
    1) Turn off caps-lock please.
    2) I stopped listening after you said you were giving "body shop" advice. Bodyshops know little or nothing about detailing, in my experience.
    Now, the reason you don't want to use spray paint is, well, rather simple. The tires are porous and flexible. Paint seals those pores and then the tire won't be able to "breathe" properly -- and effectively that will shorten the effective life of the tires. The rubber will simply start to rot from the inside out.
    Feb 2006
    NJ
    Then why are tire treatments oil based? Oil doesn't let anything "breathe". Do you have an answer there "Mr. Wizard"/ "Bill Nye The Science guy".
    Lansing, MI USA
    '99 Z28
    Ignorance is bliss for you, I suppose. Not all tire treatments are oil based -- in fact the GOOD ones aren't oil based.
    Rule #1: Never listen to a body shop when they give detailing advice.
    Member 97PredatorTA's Avatar
    Tinley Park, IL
    '97 Trans Am
    Spray painting your tires? WTF?
    Remind me to never bring any of my cars to your body shop.
    Member mdevecchio's Avatar
    Maryland
    2000 Formula
    What tire dresser will cause my tires to crack? Seems armoral (spell?) dry's and cracks my tires....
    been using black magic latley but tires were already cracking.
    This was a problem on my old tires, waiting on answer before I do new ones...
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    medevecchio: The Meguiars stuff I mentioned above hasn't caused any trouble on my car or any of my friends' cars.
    It seems to be more of the liquid and spray types that cause problems. I think a gel may be your best bet.
    Maryland
    2000 Formula
    Thanks, I'll pick some up....
    I hate to ruin a set of tires.
    Lansing, MI USA
    '99 Z28
    Quote Originally Posted by jimbo98z
    I agree about the Meguiar's stuff... but disagree with the reason why. The liquid/spray versus gel has nothing to do with whether it'd dry/crack/rot the tires or not. The difference is between solvent/silicone based dressings and water based dressings. Solvents and silicones will cause dry rot and cracking, water based dressings don't and are perfectly safe to use. That's why it's so important to stay away from the solvent/silicone dressings whenever possible. I've found VERY FEW times that a solvent/silicone dressing was called for over a water based one.
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    Maybe it's just that the sprays are more commonly the solvent type. Basically what I was getting at is that every person I've seen with problems cause by a tire treatment has been using some form of spray stuff.
    Bottom line: use the Meguiars gel stuff.
    Maryland
    2000 Formula
    Thanks all for the heads up... Gel it is
    Virgina
    98 Trans Am
    What Jimbo said....
  1. I'm sure he'll get the same treatment
    By GTP231 in forum Political / Debate Forum
    Last Post: 01-22-2015, 06:35 PM
  2. Question: System Treatment
    By 02 Camaro SS SLP in forum General Help
    Last Post: 06-11-2010, 05:40 AM
  3. Does anyone ever use fuel treatment???
    By laviente in forum General Help
    Last Post: 09-13-2009, 03:48 AM
  4. Glass Treatment
    By j12h in forum Appearance Section
    Last Post: 11-17-2008, 01:00 PM
