Results 1 to 20 of 32
    Junior Member laviente's Avatar
    omaha,NE
    Does anyone ever use fuel treatment???
    I am about to drive my goat to FL and I was jw if I should buy fuel treatment like seafoam, b-12 chemtool, lucas fuel injector cleaner, or anything like that??
    omaha,NE
    or would it be a waste of money
    I run TC-W3 in all our vehicles and once a year use Chevron's Techron Fuel System Cleaner.
    Member blackcar's Avatar
    Arkansas
    '02 Z28 parting-out
    Turgid Member Goat-E's Avatar
    Jun 2009
    Hollywood, Florida by way of Da' Burgh
    Impulse Blurr
    2004 GTO
    Quote Originally Posted by blackcar View Post
    Thanks for saving me the time.
    omaha,NE
    lol. thanks a bunch guys
    Arizona
    Thats good info that Sarge provided.
    I stick with the Lucas fuel treatment myself. I'm too lazy to get out the graduated cylinder and start measuring 2 cycle oil, although a great alternative and much cheaper, you have to be carefull of quantities. When trying to use it in 8 different running cars it becomes a second job. I generally don't come straight home after I fillup. Usually I fillup while I'm out on the run. So taking a bottle with me for when the time comes works for me. Kinda hard to measure out 2 cycle oil at home when I don't know how much gas I'm pumping in.
    Lucas fuel treatment isn't as critical, I don't have to bother with measuring. I just fill the little bottle and bring it with me. Much more user friendly for my situation.
    But I also only use it on every 5-6 fillups anymore, so a gallon goes a long way for me.
    Jun 2009
    Impulse Blurr
    2004 GTO
    I put 10 gallons in the tank at a time and use my old Lucas UCL bottle that measures in 2 ounce increments to put the TCW3 oil in. I keep the bottle under the trunk mat with the spare. How do you like them apples?!
    Arizona
    Quote Originally Posted by Goat-E View Post
    If it works for you that's great. I based my decision off of multiple cars and ease of use. If I only had 2-3 cars I would probably go through the trouble with the 2 cycle stuff.
    Jun 2009
    Impulse Blurr
    2004 GTO
    Wouldn't it be easier/less expensive to get the TCW3 by the gallon and a funnel and you could use your old Lucas bottles and have one in each vehicle?
    That's what I do. I use the gallon to fill two smaller bottles, one in my truck and another in the garage. We have 5 vehicles on the road right now and it has not been a problem. After doing this for the past 3-4 months it is just habit.
    Seafoam in the Grand Ma GT once a year.
    I will seafoam the T/A (small amount in the fuel) once in a while.
    BG44K is supposed to be a good additive. Not much experience with it though.
    Arizona
    I'm sure it would be cheaper. I've used Lucas for so long that my little bottle doesn't have measurements on the sides, it's probably 4-5 years old?? I wouldn't know how much I'm dumping in. Maybe the new ones do??? I've bought that stuff by the gallons for years and haven't looked at the little bottles anymore.
    But I would definately need several bottles with 2 oz. increments on the side. Then my only problem would be memory. If a car sits for a month I can't remember if I used it at the last fillup, therefore how much I need to measure.
    Cedars, Pa
    '02 Camaro SS
    Any place where I could get the Pennzoil Marine full synthetic for anything less than two arms and a leg?
    Arizona
    How much are you seeing it for?? I didn't think it was that expensive last time I saw it,,,compared to $30 a gallon I'm paying for Lucas fuel treatment that is....
    Cedars, Pa
    '02 Camaro SS
    $68+ a gallon?
    http://oilstore.stores.yahoo.net/pen100synout.html
    Senior Member Z28_Driver's Avatar
    Jun 2009
    Ohio
    Sunset Orange Metallic
    2002 Z28 Hardtop
    I looked at the whole forum on the 2-cycle oil. looks like a good deal.
    thanks for the link.
    Arizona
    Quote Originally Posted by SSnow View Post
    Whats all the talk about it being cheaper than Lucas then???
    Jun 2009
    Impulse Blurr
    2004 GTO
    I got a gallon of Pennzoil Full Synthetic TCW3 yesterday for $34.99 at West Marine. I guess it pays to live near the ocean in this case. 1 gallon of TCW3 = 4 of the large bottles of Lucas. At approximately $9 per bottle of Lucas you break even by volume. You use 1/3 less of the TCW3 which amounts to a savings of around $11.00 overall.(It's called MATH people) Whoever is charging you $68 a gallon should be arrested for THEFT! Here's West Marine's TCW3 prices
    http://www.westmarine.com/webapp/wcs...key=SiteSearch
    $34.99 baby!!!
    Feb 2006
    GARDEN GROVE, CA
    BLACK
    2002, CAMARO Z28
    I have tried about every fuel system cleaner and the only one's that worked were Seafoam and Lucas. I once got a bad tank of gas and a lean code for for bank 1. Added a can of Seafoam and after 20 minutes the car ran good again and the code didn't comeback. The lucas helped a lot with mpg for me. Redline is supposed to be good but made both me and my wifes car gets worse mpg, weird.
  1. I'm sure he'll get the same treatment
    By GTP231 in forum Political / Debate Forum
    Last Post: 01-22-2015, 06:35 PM
  2. Fuel Treatment- Is it worth it?
    By bman149 in forum Domestics and Foreigns
    Last Post: 07-16-2011, 12:27 PM
  3. Lucas oil fuel treatment in LS1 engine?
    By mammoth713 in forum General Help
    Last Post: 01-10-2011, 04:43 PM
  4. Stabil and fuel treatment
    By slikws6 in forum General Help
    Last Post: 12-01-2008, 04:32 PM
  5. Best Tire Treatment?
    By Waynestep in forum Showcar and Detailing
    Last Post: 04-13-2006, 02:04 AM
