Results 1 to 20 of 20
Thread: New Comp Thumper cam
01-24-2011, 03:06 PM #1
01-24-2011, 04:48 PM #2now greybat66
- Apr 2007
- bloomfield nj
Red- 1998 trans am
nice good luck when getting her tunned let us know horsepower numbers once u get it tunned.
01-26-2011, 01:27 PM #3
Sent PCM to Frost because I dont think she'll make it to a dyno(not running very good)...should b on the road next week...Can't wait!!!
01-27-2011, 11:00 AM #4
That's the smallest of the thumpers they make. I'm running the Mutha-Thumper (the middle of the 3 versions).
Did you degree it? I see on your cam card they are calling for a 103* intake centerline. That's 6* advance from your 109* lsa.
Mine was a 107* lsa with an intake centerline of 102*. Not as much advance ground into mine.
They make a nice flat torque curve that comes in quick and stays there.
01-27-2011, 04:37 PM #5
I put it in straight up..not to worried about it for now..And yes I know it's the smallest thumper. didn't want BIG...Thats what my '79 Chevy K-20 w/454 is for
01-27-2011, 04:49 PM #6
Damn sounds good man can't wait to see the numbers after the tune!!
01-27-2011, 07:46 PM #7
yeah I would be interested in the numbers.
01-28-2011, 07:24 AM #8
Just a heads up,,,,the tight LSA and the overlap these cams have don't produce alot of vacuum. Your power brakes might have fits.
I run mine in a 406 and even that large of an engine still only produces about 6-8 inches of vacuum at idle.
01-28-2011, 01:28 PM #9
^^^^I had 18in When it did idle....going to check it again i get my PCM back from Frost
02-02-2011, 04:35 PM #10
Just got the PCM back in...Plan on taking her out tomorrow if it's not raining...no more stalling out..
02-02-2011, 06:01 PM #11
Sweet you should take a video of it to, can't wait to see how she runs what does she idle at now?
02-08-2011, 05:08 PM #12
WOW!!! 1st,2nd&3rd up in smoke...Idle is alot smoother..I'll get a video soon
02-08-2011, 05:19 PM #13its short but its skinny.
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
what kinda heads are on it?
02-08-2011, 06:42 PM #14
That's what an early flat torque curve will do for ya. Makes for a very fun street car.
02-09-2011, 02:40 AM #15
02-09-2011, 04:28 AM #16its short but its skinny.
- Oct 2009
pewter- 99 trans am
yea id like to know the hp numbers as well....especially with stock heads...if its nice, i may go with somethin like this.
02-09-2011, 06:22 AM #17
did u have to put in different lifters or anything else when you put the cam in? or did you just put the cam in and go? well with the tune of course too haha..im very interested in doing this and just wanted some input on your setup. sounds great btw!
02-09-2011, 10:06 AM #18
I wouldn't get too caught up on HP numbers. That's not what this cam was really designed for, although it should make respectable HP. They shine more with a nice flat torque curve that comes in early in the rpm range due to their tight LSA. That's what makes the car fun to drive.
I run the bigger version of this cam, and Comp says it starts making power as early as 2,000 rpm and peaks at 6,100. That's in a little 350. I'm running it in a 406. I can tell you it makes gobs of torque nearly right off idle and has extremely snappy throttle response.
02-09-2011, 10:57 AM #19
02-09-2011, 04:56 PM #20
LS3 Supercharger Install - Street Thumper!
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 08-03-2012, 02:40 PM -
Question: Comp Thumper cams
By turbodarryl in forum Internal EngineReplies: 5Last Post: 01-20-2009, 11:15 AM -
402 Chevy LS2 Short Block Engine Build - Thumper
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 10-17-2008, 06:10 PM -
Comp Cams New Thumper Cams
By Z ROADSTER in forum Internal EngineReplies: 6Last Post: 08-27-2007, 12:39 PM
[/IMG]
