    OC, California
    1999 Z28 M6
    Question what all do i need to replace?
    my clutch and master are goin out so im wanting to replace everything. what all do i need to buy to replace? clutch, master and slave cylinder, throw out bearing, pilot bearing???? for anyone who has replaced everything, let me kno what u replaced and that would be a big help, thanks guys.
    OC, California
    1999 Z28 M6
    anyone?????
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    I just ordered and recieved my parts SPec 3 plus clutch, pressure plate, throw out bearing, pilot bearing, new steel Spec flywheel, 01-02 slave cylinder, and master cylinder. If your going to do it replace everything at once.
    3 inch Chambered Catback.
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    Quote Originally Posted by FastAssZ
    I think you've about got it covered there.
    Member cailey37's Avatar
    Mississippi
    1998 Pontiac Trans Am
    some good advise....stay away from the SPEC clutches.......go with a Centerforce!! I've got SPEC clutches going out all around me!
    Member mikeaford's Avatar
    Fredericksburg Va
    01 Trans Am
    I got a Z06 clutch package off of ebay with the fidenza alluminum flywheel, then bought a new stock master and slave cylinder from one of the sponsors on here. GM parts direct, the throw out bearing arrived cracked in my ebay package but they quickly sent me a replacement but one already came installed on my new slave cylinder so I have a spare sitting around. I had the flywheel machined they said it was rare they actually had to take some metal out instead of welding some on which is always better. Got it put in and I am pretty happy so far. I also changed a leaking differential rear seal why I was in there and had the driveshaft out.
  1. Question: What else can i replace
    By izzhemp in forum Firebird / WS6
    Last Post: 05-25-2011, 01:07 PM
  2. How to replace u joint?
    By freddy_caprice in forum Drivetrain
    Last Post: 05-11-2009, 03:19 PM
  3. How to replace TPS?
    By Firebird Phoenix in forum V6
    Last Post: 01-01-2009, 07:58 AM
  4. Question: Replace PCV?
    By kool-aide in forum General Help
    Last Post: 08-10-2008, 02:08 PM
  5. What else should I replace?
    By Roastem in forum Manual Transmission
    Last Post: 03-12-2008, 10:59 AM
