Results 1 to 13 of 13
    aurora
    How to replace u joint?
    So I finally figuured out that the loud noise in the rear end was being caused my worn out ujoint. My question is how do I replace it? Also is there a certain brand I should go with? I was looking at some online and notice that it said greeced and non, is there a certain lube to use on the u joint? Thanks
    Member Benner's Avatar
    Delaware, OH
    2001 GrandPrix GTP
    Sorry to say this but just take it to the dealer to get replaced. It'll save you a real headache. Lot of heating hammering and luck involved with them.
    Member zmg00camaross's Avatar
    missouri
    pewter
    2000 camaro ss
    Remove drive shaft. Remove outer caps and take big fuckin hammar (bfh) and beat on the cross until it pushes the cap out then beat it the other way to remove other cap. Or use proper tool to remove which makes it easy.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    wow...
    Get a propane torch and heat up the caps till the plastic resin comes out that is holding them in.. you will know when it comes out.. then just buy a u-joint press, they are cheap on egay. It will save you a headache of a GM dealer and quit a few dollars.
    Quote Originally Posted by Benner View Post
    Hello $85/labor hour
    If you really don't want to do it yourself, take it to a drivetrain specialist shop, they will probably charge your $30-40 to swap it out. I would avoid the stealership though, I am sure it would be over $100 at a stealership to get it done.
    Beaver Dam KY
    79 T/A -91 Firebird
    Got mine quoted locally at 60 bucks a u joints.. Aint worth it IMO
    Delaware, OH
    2001 GrandPrix GTP
    Local shop would be fine. I hated changing them when I worked at a dealership.
    aurora
    Thank you all for the replies. What about Greeced and non greeced u joints? I think thats what they are called.
    Beaver Dam KY
    79 T/A -91 Firebird
    Quote Originally Posted by freddy_caprice View Post
    Greasable u-joints sounds like a good idea but it isnt. They are hollowed out even more and its a good chance for them to break. Lakewood solid u-joints are the way to if possible
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Agreed. The non-greasable u-joints have less likelihood of failure due to being stronger, and are come pre-greased with synthetic lubricant.
    Just install them and you're set, no need to regrease.
    Unbiased Opinion 67rsss's Avatar
    MN
    The u-joints with zerk fittings shatter when they fail. Don't do it.
    U-joint replacement the easy way.
    Had to swap out our rear u-joint back in March. I do not like beating on aluminum driveshafts with a hammer. Made this tool out of a slice of 2" x 4" rectangular tubing, cutting one end off, and a few pieces of flat stock. Welded it up and reinforced it a bit more than needed probably (no laughing at the welds!) as I will also use it on other vehicles.
    Placed the driveshaft in the press, put a large socket under the cap to be pressed out, and postioned the tool so that the arms rest on each side of the cross. The ends are slightly dished to keep the tool centered over the u-joint as pressure is applied. This allows the joint to be pressed out without any risk of collapsing or damaging the yoke. Worked like a charm -- total investment a few pieces of steel that were laying around the garage, a little work with the Sawzall, and about 10 minutes of welding.
    aurora
    Great advice guys thank! I love this forum.
  1. u joint help
    By SilverBulletLS1 in forum Drivetrain
    Last Post: 01-16-2014, 07:06 AM
  2. Question: u-joint replace?
    By monster500s in forum Drivetrain
    Last Post: 07-19-2012, 02:09 PM
  3. So tell me about my u-joint
    By goof4080 in forum Drivetrain
    Last Post: 07-03-2012, 03:44 PM
  4. Question: u joint??
    By Karczewski in forum General Help
    Last Post: 10-26-2011, 09:22 AM
  5. Question: Bad u-joint???
    By joedude02 in forum General Help
    Last Post: 11-02-2008, 09:09 PM
