Results 1 to 3 of 3
Thread: Bad u-joint???
11-02-2008, 02:27 PM #1
Bad u-joint???
my car makes a loud whining noise when i let up off the throttle like when approaching stop lights. doing some reading and sounds like it's either my u-joint or the actual posi unit. anything further on this noise? it does not make noise when accelerating at any time and nothing is heard on any turns. just when the car is decelerating. the sound will go away when taken out of gear. help on this before i start spending money i don't need to spend. everything is stock, so i hope not to be buying a strange or moser anytime soon.
11-02-2008, 09:24 PM #2
Mine was making that sound too. I took my diff cover off to find the the carrier for the posi unit cracked.
I was hoping it was something small but it wasnt. So over winter i have to save up for 9"
Hope it aint as bad for you. It sucked when I found that out
11-02-2008, 10:09 PM #3Just a souped up sunfire.
- Jun 2007
- Parma Heights, Ohio
SOM- 99 Trans Am
U joints usually clunk when they are going. The whine (usually comes from the gears) is very common in our cars but if it goes away when you put it in neutral id look more at the tranny
u joint help
By SilverBulletLS1 in forum DrivetrainReplies: 4Last Post: 01-16-2014, 08:06 AM -
So tell me about my u-joint
By goof4080 in forum DrivetrainReplies: 3Last Post: 07-03-2012, 04:44 PM -
Question: u joint??
By Karczewski in forum General HelpReplies: 4Last Post: 10-26-2011, 10:22 AM -
U-Joint
By 01CalgarySS in forum DrivetrainReplies: 3Last Post: 09-18-2008, 06:43 PM -
U-joint squeaking?
By B200 in forum DrivetrainReplies: 0Last Post: 08-10-2007, 07:58 PM
