Results 1 to 11 of 11
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    New dip stick tube
    Ok so long story short, my girlfriends Oldsmobile Alero needs a new dipstick and tube...
    how hard is this to install? can I do it myself pretty easy?
    My other question is, if/when i remove the tube, is oil going to go everywhere? should i drain the oil first?
    Ive always changed my own oil, and I've changed it in her car, but i don't know anything about dip stick tubes.
    Feb 2006
    2002 WS6
    not 100% positive on how they are installed on the V6s, but gonna guess that it would be like most tubes where it is a friction fit at the pan or where it ever it enters into the pan, Oil won't or at least shouldn't splash or leak, may drip a bit.
    Also make sure that everything near, around and on the tube and location of the tube is 100% spotless. Don't need to suck a piece of dirt into a bearing or something.
    2000 SS Black M6
    Friction fit?
    LS6 intake, Pacesetters, TSP rumbler !EGR, !AIR, 295/35 BFG KDW II's, UMI Adj LCAs. Tick Master Cylinder, LS7 Clutch and flywheel, Pro 5.0, Lous short stick, Frost Tune.
    Pittsburgh
    2008 Hummer H3
    What engine? It will have an O-ring that fits very tight in the hole..
    You won't have to drain anything..
    It will likely have (2) 8mm bolts to secure it one @ the bottom in a flang attached to the tube and another @ about the middle secured to the block..
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    If its the 3400 V6, I think you have to remove the front exhaust manifold to be able to snake it out of there. I remember removing a few during some head gasket repairs. Some come out nicely, some come out pretty difficult.
    Pittsburgh
    2008 Hummer H3
    They can be a pita.. But I think you're talking about this engine as far as the manifold goes..
    2000 SS Black M6
    yeah im pretty sure thats it
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    You have your work cut out for ya then bro.. I think you can handle it tho..
    If you could rip your front end off your old car you can take care of this..
    It's just a cramped pita. I would recommend the manifold being slightly warm (not hot) when you pull it..
    Sometimes when they are cold the bolts don't like to cooperate.. Good luck..
    Madison, WI
    2001 Silverado Z71
    The crossover pipe studs like to break but they are easily available from GM. We went through a bunch of them back in the day.
    2000 SS Black M6
    Oh you remember that thread, lol....I'll get under it and try it sometime....but it's looking like I have to change it this time and just trust that I'm putting in the right amount
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Yeah There as so few new v6 threads they're relatively easy to remember.
    4.5 quarts with some poured into the new filter..
  1. Dip stick tube
    By Joels1 in forum External Engine
    Last Post: 03-28-2010, 09:16 AM
  2. 04 C5 A4 vs 09 350Z stick vz 370Z stick
    By Danger731 in forum Kill Stories
    Last Post: 03-27-2009, 03:03 PM
  3. long tube vs. short tube
    By beer in forum External Engine
    Last Post: 02-12-2009, 02:21 PM
  4. need asap transmission dip stick tube.
    By 1fastcamarosss11 in forum Parts Wanted / Trade
    Last Post: 07-11-2007, 03:17 PM
  5. WTB tranny cooler, Trans Dip stick tube...
    By jwitt2 in forum Parts Wanted / Trade
    Last Post: 06-04-2007, 11:59 AM
