Results 1 to 20 of 22
Thread: Dip stick tube
03-22-2010, 03:17 PM #1Member
- Jan 2008
- Dighton Massachusetts
Black soon to be red- 2000 Trans am Ws6
Dip stick tube
I unbolted the 15mm bolt for the dipstick tube but it`s a mother to get the tube out itself...pb blasted it an all?
03-22-2010, 03:20 PM #2Just a souped up sunfire.
- Jun 2007
- Parma Heights, Ohio
SOM- 99 Trans Am
it just slides out. keep fighting it, itll happen eventually haha. just sucks cus its angled and that makes it harder
03-22-2010, 03:20 PM #3
wiggle it back and forth while pulling....it'll come out. There's just an o-ring holding it in there but it takes some wiggling and pulling to get it out of there sometimes.
03-22-2010, 03:21 PM #4Member
- Jan 2008
dipstick tube
Ok going into the garage gonna give it a go....thanks.
03-22-2010, 05:48 PM #5
03-22-2010, 05:51 PM #6
I had my starter out when I pulled mine. Used a small flat blade screwdriver to pry it up out of the hole -- very easy.
03-22-2010, 05:54 PM #7
03-22-2010, 07:34 PM #8Member
- Jan 2008
Dip stick tube
Holy shit almost popped a blood vessel getting it out....damn busted my knuckles though
03-22-2010, 07:40 PM #9
you get it out then? I've found when I run into this type of stuff it's no so much the technique that gets it out but the well thought out synchronized array of cuss words that do the trick.
03-22-2010, 07:45 PM #10BANGIN GEARS>STAB N STEER
- Nov 2009
- Jacksonville FL
TRIPLE BLACK- 2000 CAMARO SS M6 #2100
, that sucks man. I keep hearing all these horror stories about the dip stick tube but i guess ive just been lucky in the numerous header installs ive done. It always seems to just pop right out, lol. This may be a really dumb question but did you take the actual dipstick out first?
Maybe its harder to get out with it in there...
03-22-2010, 07:47 PM #11
03-23-2010, 01:35 AM #12Senior Member
- Jan 2010
- texas
silver- 2000 formula
holy moly.......my dip tube practically jumped out
03-23-2010, 05:12 AM #13
03-23-2010, 11:19 PM #14
03-24-2010, 05:53 PM #152002 Arctic White T/A
- Sep 2009
- Houston , Texas
Metallic Pewter- 2002 SLP Firehawk
lol i had trouble with the dipstick but instead it was going on i had trouble with...i belive i called a a effin whore at some point lol..
03-27-2010, 10:05 PM #16
But, technically speaking, if it were a f'n whore, shouldn't it slide in and out easily?
BTW- you guys are making me nervous- I'm installing my headers in a couple of weeks and I've got a running list of pains in the ass I'll have to deal with: dipstick, AIR, y not fitting... damn.
03-27-2010, 10:28 PM #17
what headers and Y? None of this stuff is hard....mostly just time consuming and from time to time something simple will make it rough on you ( like the dipstick tube). You wanna talk PIA bolts.....the bolt for the a4 tranny dipstick tube is a huge PIA. The bolt for the oil pump tube is too.
03-27-2010, 11:32 PM #18
i just gave mine a tug. easiest part of the header install
03-28-2010, 04:36 AM #19
mine didnt want to come very easy, till i stuck a bolt in the dip stick hole and used vice grips, popped right out then.
03-28-2010, 05:10 AM #20
I agree -- it's not difficult, just time consuming. Accessing some of the bolts is a bit of a challenge. I had my front end covered with towels so I could lay across the car to reach back in under the cowl. Make sure you pop the cowl seal clips out before you get started. Those things will shred your hand in a hurry.
Help: New dip stick tube
By Spikito in forum General HelpReplies: 10Last Post: 01-23-2011, 08:06 AM -
04 C5 A4 vs 09 350Z stick vz 370Z stick
By Danger731 in forum Kill StoriesReplies: 26Last Post: 03-27-2009, 03:03 PM -
long tube vs. short tube
By beer in forum External EngineReplies: 10Last Post: 02-12-2009, 02:21 PM -
need asap transmission dip stick tube.
By 1fastcamarosss11 in forum Parts Wanted / TradeReplies: 6Last Post: 07-11-2007, 03:17 PM -
WTB tranny cooler, Trans Dip stick tube...
By jwitt2 in forum Parts Wanted / TradeReplies: 0Last Post: 06-04-2007, 11:59 AM
twist and wiggle while pulling it should be all u need to do... good luck
i concur
