Results 1 to 14 of 14
    Junior Member Tampa T/A's Avatar
    Apr 2010
    Tampa
    02 WS6
    Blinking "Service Engine Soon Light"??
    Hello everyone, a while back I posted the code that was making my light come on. Passanger side cat failure. Since im getting ready to pull them soon, I did not get it fixed. But since then..... every so often the service engine light blinks sometimes fast, sometimes slow. As if it were saying " hey ASSH@LE!! Look at me!!" So I am going home here soon & will check to see if there are any more new codes. I do have a oil pan gasket leak to fix very soon but I dont think that would make the light blink like that. Is this normal or has anybody else seen this before?
    blinking light can be misfires. Is the car missing at all? I would get it scanned again and see what codes show up.
    Apr 2010
    Tampa
    02 WS6
    No.... runs great!! I have a Hypertech tuner so I can check codes myself. I will follow up with you though.
    The flashing SES light means misfires, according to the owners manual. The only time I ever had a flashing SES light was due to misfire. Even though you may not be noticing anything, if you got a flashing light, I would be real careful about driving it until you get it resolved.
    Flashing is multiple random misfires. It is also an indicator to not drive it. More serious issue when flashing.
    Pull codes. Probably has to do with that cat/O2 issue.
    Apr 2010
    Tampa
    02 WS6
    OK guys, sorry it took so long to get back with you all. Had to dig out the tuner from storage so I could check for newe codes. So here they are: P0171 Sys too lean Bank 1,
    P0174 Sys too lean Bank 2, P0300 Random/Multiple Cylinder Misfire Detected, P0430 Catalyst Sys Efficiency below Threshold Bank 2.
    So I have been driving it a little bit due to not wanting to ride the GSXR in 30 degree weather. My idle has been fluxuating a little bit. Sometimes dropping to 500rpm. I have things set up for Feb. 7th to change my oil pan gasket, install long tube headers & ORY,new plugs & wires. Then it looks like I will be visiting our sponser TampaTuning for a tune. Can someone help me translate these codes & will this work I have done to the car fix my problems? I also have a crack/hole in the vacume line coming off the passanger side of my throttle body. Dealer wants to sell me the whole line for over a 100 dollars. Is there a cheaper way to fix this? Why would the car be misfireing? The SES light only blinked during aggressive driving. Really need some advice here & the car is now parked till Feb. 7th. Thanks
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Your cracked PCV hose could be most of your problems there. Here's a cheaper fix idea from one of our stickys in the Gen Help forum.
    PCV Valve Recommendation / Housing Modification
    Another alternative is to convert to a LS6 style PCV system with a catch can and new valley cover.
    Apr 2010
    Tampa
    02 WS6
    Thanks Cutlass, I knew there was a sticky somewere.
    Member 1998 T/A's Avatar
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    Solution?
    Apr 2010
    Tampa
    02 WS6
    Well, I did the PCV valve housing modification. It all fits together really well & has cleared three of my DTC codes. So it no longer misfires & is no longer running lean. Great write up on that modification. Spent less than 20 bucks. I will post a pic this weekend.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    I would also suggest changing your plugs because they may have been damaged by the misfiring...happened to my GTP after a leaning condition caused misfiring...here is the result:
    The tips are gone from four and the arc is gone from two.
    Ohio
    Green
    95' Trans Am
    What about a solid "Service Engine Soon" light in a 95 TA?
    Laurel, Maryland
    2000 Grand Prix GTP
    Quote Originally Posted by Green95TA View Post
    Means go to Auto Zone and get your car scanned for codes.
    is your car obd1 or obd2? OBD1 will be a 12 pin connector. If it is you can jump the A-B pins with a paper clip and count the flashes to get the code. If it's OBD2 you'll have to use a reader.
    OBD1 pinout
    jump the A-B pin and there will be a series of flashes (first number) pause series of flashes(second number).
  1. Question: "Service Engine Soon light" Got a P0430 code
    By gymrat11 in forum Camaro / SS
    Last Post: 01-09-2014, 07:42 AM
  2. Help: "service engine soon"
    By pmolina0436 in forum GTO
    Last Post: 11-26-2012, 08:26 PM
  3. Help: Service Engine Soon Light On ???"s
    By dickeymoore in forum General Help
    Last Post: 07-02-2012, 07:32 AM
  4. Help: "service engine soon"
    By Sayed_000 in forum General Help
    Last Post: 12-02-2008, 02:31 PM
  5. Grand Prix GT "check engine light"
    By rschap1 in forum Almost Anything Goes
    Last Post: 10-24-2008, 06:20 PM
